More testing for VLC 3.0.5?
Those that have installed it from the test repo with MXPI say it went without any problems, and it provides working va-api hardware acceleration for Intel GPUs where the Stretch 3.0.3 version is broken because of our newer libva and ffmpeg. Getting va-api acceleration working on Intel involves installing i965-va-driver, though...we probably should include that on the ISO in the future if we update VLC.
I'd like to see a few more positive reports from users before we move 3.0.5 and its load of newer libraries to the main repo, though. It requires a newer libbluray and phonon, for example, among others.
Re: More testing for VLC 3.0.5?
I have the i965 driver installed and I noticed that while I still appear to have ffmpeg va-api hardware decoding in ffmpeg (mpv), I have lost hardware encoding. ffmpeg fails with:Stevo wrote: ↑Wed Jan 02, 2019 3:28 pm Those that have installed it from the test repo with MXPI say it went without any problems, and it provides working va-api hardware acceleration for Intel GPUs where the Stretch 3.0.3 version is broken because of our newer libva and ffmpeg. Getting va-api acceleration working on Intel involves installing i965-va-driver, though...we probably should include that on the ISO in the future if we update VLC.
ffmpeg: i965_encoder.c:1692: intel_enc_hw_context_init: Assertion `encoder_context->mfc_context' failed.
ffmpeg works fine without hardware accel.
Hmmm--what do you get for
apt policy ffmpeg i965-va-driver
ffmpeg:
Installed: 7:3.3.4-1mx17+2
Candidate: 7:3.3.4-1mx17+2
Version table:
*** 7:3.3.4-1mx17+2 500
500 http://mxrepo.com/mx/repo stretch/main amd64 Packages
100 /var/lib/dpkg/status
7:3.2.12-1~deb9u1 500
500 http://ftp.us.debian.org/debian stretch/main amd64 Packages
500 http://security.debian.org stretch/updates/main amd64 Packages
i965-va-driver:
Installed: 2.2.0+dfsg1-2~mx17+1
Candidate: 2.2.0+dfsg1-2~mx17+1
Version table:
*** 2.2.0+dfsg1-2~mx17+1 500
1.7.3-1 500
- mmikeinsantarosa
I loaded up 3.0.5 and all the plugins and nothing untoward to report here.
Are there other media players besides VLC that anyone uses to play blu-ray media (I have no idea as I don't even watch bluray stuff)? Is this other player still able to play bluray media after the installation of the new libraries? That might be a relevant test.
The "+2" at the end of the ffmpeg version shows that's the version I rebuilt against our current Mesa and libva libraries in to get va-api working for playback, so I don't have any idea why that broke it for encoding.clicktician wrote: ↑Thu Jan 03, 2019 10:47 amCode: Select all
ffmpeg: Installed: 7:3.3.4-1mx17+2 Candidate: 7:3.3.4-1mx17+2 Version table: *** 7:3.3.4-1mx17+2 500 500 http://mxrepo.com/mx/repo stretch/main amd64 Packages 100 /var/lib/dpkg/status 7:3.2.12-1~deb9u1 500 500 http://ftp.us.debian.org/debian stretch/main amd64 Packages 500 http://security.debian.org stretch/updates/main amd64 Packages i965-va-driver: Installed: 2.2.0+dfsg1-2~mx17+1 Candidate: 2.2.0+dfsg1-2~mx17+1 Version table: *** 2.2.0+dfsg1-2~mx17+1 500 500 http://mxrepo.com/mx/repo stretch/main amd64 Packages 100 /var/lib/dpkg/status 1.7.3-1 500 500 http://ftp.us.debian.org/debian stretch/main amd64 Packages
We also have a newer ffmpeg 4.0.3 in the test repo that you can try, but it may have the same problem. It installs newer versions of libraries alongside the standard ones, libavcodec58 alongside libavcodec57 as an example, so won't break VLC va-api playback.
Ah. Thanks, man. No worries. The gods of linux giveth... and they taketh away. Hahaha.
I wonder if the static ffmpeg version you can download and just run in a directory supports the va-api encoding.
https://johnvansickle.com/ffmpeg/
Edit: the Google says not:
This is nothing to do with ffmpeg: libva cannot be linked into a static binary because it requires the dynamic linker to do driver loading.
- entropyfoe
Stevo,
I had a few minutes spare last night so I grabbed 3.0.5 from the test repo and installed.
Out side of lots of packages, the install went well, and I tested on three different media file formats, all seemed to work normally, so it is working for me at a basic level.
Asus PRIME X470-PRO
Nvidia GeForce GT 710
on-board ethernet & sound
