MX-18 GNOME question
- joejohnston3
Hello All,
I have always been a GNOME person and decided to use it with MX-18. It works amazingly well but I noticed a hidden bar in the bottom left of my screen, showing running apps and wondered what program or extension it was. I have attached a screenshot and wanted to see if anyone was familiar with it and knew what it was. Thank you.
Joe Johnston
iMac with MX Linux 17.1 GNOME
Re: MX-18 GNOME question
from left to right: Teamviewer ; MX usb unmounter ; ClipIt , MX Updaterjoejohnston3 wrote: ↑Sun Dec 23, 2018 8:11 pm I have attached a screenshot and wanted to see if anyone was familiar with it and knew what it was.
4 points of 4
MX-18 doesn't have the first two characters from the left but the third one is Unmount, the fourth is File Operation, the fifth one is the Updater.
I think it's the system tray
- joejohnston3
I need to clarify and sorry for the confusion. I wanted to know what the tool is that is showing the running tasks. I know which tasks are running but am not familiar with the task manager that is running and hiding in the left hand corner. Is it an extension or a startup application and what is its name?
Joe Johnston
I never seen such an icon on any version of MX Linux. Must be a Gnome thing.joejohnston3 wrote: ↑Sun Dec 23, 2018 8:33 pm I need to clarify and sorry for the confusion. I wanted to know what the tool is that is showing the running tasks. I know which tasks are running but am not familiar with the task manager that is running and hiding in the left hand corner. Is it an extension or a startup application and what is its name?
One of it names is "status icons", another systrayjoejohnston3 wrote: ↑Sun Dec 23, 2018 8:33 pm I need to clarify and sorry for the confusion. I wanted to know what the tool is that is showing the running tasks. I know which tasks are running but am not familiar with the task manager that is running and hiding in the left hand corner. Is it an extension or a startup application and what is its name?
https://blogs.gnome.org/aday/2017/08/31 ... and-gnome/
And it appears to be a fading away feature, not shown since version ~ 3.26 ...
ok... I've been lurking and just have to say... @joejohnson3 most of us here are much better equipped to help with xfce... but you already knew that... btw. I liked gnome in the old days way before gtk3.
- joejohnston3
I do appreciate you all giving input as I am aware that Xfce is predominate here and I am outside the wire but I am enjoying MX-18 with GNOME. :)
Joe Johnston
I also noticed the hidden bar when installed GNOME in MX. Its Debian thing because Ubuntu doesn't. Not sure which package, because I installed full desktop "apt-get install gnome". I am now testing in another machine, Debian 10 Buster to check GNOME 3.30. In my main machine with Ubuntu (also MX), the speed and responds is super. In this test, by installing minimal.... may find the hidden bar. What does Google search say?
Google:
Debian -- Details of package gnome-shell-extension-taskbar in stretch
https://packages.debian.org/stretch/gno ... on-taskbar
TaskBar Extension for GNOME Shell. TaskBar displays icons of running applications on the top panel or alternatively on a new bottom panel. Activate, minimize ...
Google:
