MX-17.a4
Shay2
MX-17.a4
#1 Post by Shay2 »
Networking works like normal.
Sceenshot still shows error when saving.
inxi -Fxz
System:    Host: mx1 Kernel: 4.9.0-3-amd64 x86_64 bits: 64 gcc: 6.3.0
           Desktop: Xfce 4.12.3 (Gtk 2.24.31) Distro: MX-17.a4_x64 Horizon 6 October 2017
Machine:   Device: laptop System: Dell product: Latitude E6430 v: 01 serial: N/A
           Mobo: Dell model: 0H3MT5 v: A00 serial: N/A BIOS: Dell v: A17 date: 08/19/2015
Battery    BAT0: charge: 24.8 Wh 34.0% condition: 72.9/99.9 Wh (73%)
           model: LGC-LGC3.0 DELL J7KGM29 status: Discharging
CPU:       Dual core Intel Core i5-3320M (-HT-MCP-) arch: Ivy Bridge rev.9 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10365
           clock speeds: max: 3300 MHz 1: 1200 MHz 2: 1199 MHz 3: 1200 MHz 4: 1200 MHz
Graphics:  Card-1: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0
           Card-2: NVIDIA GF108GLM [NVS 5200M] bus-ID: 01:00.0
           Display Server: x11 (X.Org 1.19.2 )
           drivers: modesetting,nouveau (unloaded: fbdev,vesa)
           Resolution: 1600x900@59.99hz
           OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile
           version: 3.3 Mesa 13.0.6 Direct Render: Yes
Audio:     Card Intel 7 Series/C216 Family High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.9.0-3-amd64
Network:   Card-1: Intel 82579LM Gigabit Network Connection
           driver: e1000e v: 3.2.6-k port: f060 bus-ID: 00:19.0
           IF: eno1 state: down mac: <filter>
           Card-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi bus-ID: 03:00.0
           IF: wlp3s0 state: up mac: <filter>
Drives:    HDD Total Size: 136.1GB (3.3% used)
           ID-1: /dev/sda model: SanDisk_SDSSDA12 size: 120.0GB
           ID-2: USB /dev/sdb model: USB_Flash_Drive size: 16.0GB
Partition: ID-1: / size: 6.2G used: 7.3M (1%) fs: overlay dev: N/A
           ID-2: swap-1 size: 4.69GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 52.0C mobo: N/A gpu: 48.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 199 Uptime: 6 min Memory: 453.2/7893.3MB
           Init: SysVinit runlevel: 5 Gcc sys: 6.3.0 Client: Shell (bash 4.4.121) inxi: 2.3.40
Now where is persistance hidden.
Re: MX-17.a4
#2 Post by dolphin_oracle »
Shay2 wrote:Networking works like normal.
inxi -Fxz
I need a screenshot of the screenshot error. I have not been able to reproduce any error in either MX or antiX, which actually use different screenshot tools.
Shay2
Re: MX-17.a4
#3 Post by Shay2 »
And I get this error in both Antix 17 and MX 17
Re: MX-17.a4
#4 Post by dolphin_oracle »
Shay2 wrote:And I get this error in both Antix 17 and MX 17
did you install antiX screenshot on mx17? I don't think its preinstalled (unless it is and I missed it :happy:)
mx17 uses a different tool (hit PrtScrn to see it, or its in the graphical menu too).
and not to be completely ridiculous, but maybe you changed the extension. why it matters I can't tell you, but in antix-screenshot the file name you give the screenshot MUST have an extension and the extention MUST match whatever format you chose on the opening screen (default is jpg I think).
SwampRabbit
Re: MX-17.a4
#5 Post by SwampRabbit »
I know xfce-screenshooter works as expected on alpha 4 because I used it last night for my post in the other alpha thread.
I did not try the cli tool - scrot though.
Shay2
Re: MX-17.a4
#6 Post by Shay2 »
Well shutdown and reboot MX and I guess I had a one off error. This time every thing saved just fine.. Color me puzzled.
@d_o yes the default is jpg in Antix, I had the same problem in 15 until I got a update and the problem disappeared.
It never has shown up in 16.
But it is back in 17. I just remove the dot and retype it. Seems to do the trick what ever extension I try.
