Hi Jerry,
I uploaded 11.9.92.
I fixed the CD init to use Plymouth.
Also did some minor tweaks so 32 and 64 have the same installed packages.
Best,
Warren
M12 11.9.92
M12 11.9.92
Warren has uploaded a minor revision:
Re: M12 11.9.92
Downloaded the 64 bit version.
Ran mdsum--OK
Burned to 2G USB drive with unetbootin--OK
Inserted USB drive into computer at 6:38PM Anchorage time
Booted OK--Fast Too.
Installed to HDD
Failed to restart---Same as other previous betas
Hard reset
Booted into version 11.9.92--up & running by 6:50 PM Anchorage time--that is pretty darn quick, I think.
Haven't played with it much yet.
I checked synaptics, & the bug where after Mepis is selected and then checked again, prefer highest version
is automatically selected by the OS. If you then reselect Mepis, it stays as desired. I have reported this before--only a very minor irritant.
Thanks Warren
Jerry in Anchorage
Ran mdsum--OK
Installed to HDD
Hard reset
Thanks Warren
Jerry in Anchorage
Re: M12 11.9.92
11.9.92 32-bit on Fujitsu-Siemens Amilo Li 1818:
There are still 17 ghost drives in KinfoCenter. Installer freezes when finished and no automatic reboot.
Apart from that, M12 feels slightly more polished for every new release.
Haven't started testing yet, this was only a few first impressions.
The different help screens and tips in the installer need some serious proofreading. Typos like "Aafter you reboot" shouldn't be there.
And what happened to "Press F1 for help" when booting the live-DVD?
Henry
Henry
Re: M12 11.9.92
- 64-bit download from U of Crete mirror
- Loaded to USB flash with isohybrid/dd method
- Got missing media message on boot...failed
- Then added 'fromhd' cheat and booted fine...very fast
- Installed to HDD fine
Samsung 860 500GB SSDs (2)
Re: M12 11.9.92
. hey,
kernel and headers match :thumup:
easy... yep, same repo... unetboo.. looks pretty nice.
concerning the panel ... quick launcher
root@mepis:~# inxi -Fr
System: Host: mepis Kernel: 3.9-1-mepis64 x86_64 (64 bit) Desktop: KDE 4.8.4 Distro: MEPIS 12.0 wheezy
Machine: System: HP Pavilion 061 product: PX181AV-ABA d4100y version: 0qn1211CT101LITHI00 serial: MXG52500B9 NA531
Mobo: ASUSTek model: LITHIUM version: 1.04 serial: MB-1234567890 Bios: Phoenix version: 3.07 date: 08/29/2005
CPU: Dual core Intel Pentium D CPU (-MCP-) cache: 1024 KB flags: (lm nx sse sse2 sse3)
Clock Speeds: 1: 2800.00 MHz 2: 2800.00 MHz
Graphics: Card: NVIDIA NV43 [GeForce 6600]
X.org: 1.12.4 drivers: nouveau (unloaded: fbdev,vesa) tty size: 99x23 Advanced Data: N/A for root
Audio: Card: Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture ver: k3.9-1-mepis64
Network: Card: Intel NM10/ICH7 Family LAN Controller driver: e100
IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:1.10:75
Drives: HDD Total Size: 164.0GB (3.3% used) 1: id: /dev/sda model: ST3160023AS size: 160.0GB
2: USB id: /dev/sdb model: Cruzer size: 4.0GB
Partition: ID: / size: 2.7G used: 253M (10%) fs: rootfs ID: /boot size: 3.9G used: 3.7G (97%) fs: ext4
ID: /home size: 3.9G used: 3.7G (97%) fs: ext4 ID: /usr size: 3.9G used: 3.7G (97%) fs: ext4
ID: /var size: 3.9G used: 3.7G (97%) fs: ext4
RAID: No RAID devices detected - /proc/mdstat and md_mod kernel raid module present
Sensors: System Temperatures: cpu: 40.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Repos: Active apt sources in file: /etc/apt/sources.list.d/debian.list
deb http://ftp.us.debian.org/debian/ wheezy main contrib non-free
deb http://security.debian.org/ wheezy/updates main contrib non-free
deb http://ftp.us.debian.org/debian/ wheezy-updates main contrib non-free
Active apt sources in file: /etc/apt/sources.list.d/mepis.list
deb http://mepis.mirrorcatalogs.com/packages/mepis/ mepis-12.0 main
Info: Processes: 131 Uptime: 3:26 Memory: 651.0/3018.7MB Client: Shell (bash) inxi: 1.9.12
- Eadwine Rose
- Administrator
Re: M12 11.9.92
Experiencing the same things with the non proper reboot. But it spits out the disk, and the reboot button does the rest.
Re: M12 11.9.92
Just took the 32 bit version for a quick spin on a USB stick that was made by Unetbootin. Used on a Dell Inspiron 1525, 2 GB RAM. Live Disk only, not installed.
No problems booting up.
Wireless connected and worked just fine.
Bluetooth mouse connected and worked just fine.
Any of the major programs that I would used opened and functioned.
Runs smooth and snappy.
One thing that needs to be updated, is in Iceweasel, the link to the community or forums is not correct. This may have been stated on previous version of the alpha/betas.
There is no "Ctrl+Z" in life!
Asus X570, Rysen 3600, 32 GB RAM MX-21
Acer 7551G MX-21 & Win 10
Asus i5, 16 GB RAM MX-21 & Win 10
Brother DCP-7065DN/HL-L3270CDW
Linux User# 4523410
Linux User# 4523410
- BurtHulland
Re: M12 11.9.92
I downloaded and installed (HD install, not VB) both the 32- and 64-bit versions of .92. No problems (except for the intermitant crash when exiting the Live version; it happened 1 of the 2 installs), I then installed my normal suite of apps on both; again no problems and everything seems to be working.
The graphic while installing the live programs was a surprise (but I'm not sure it is better than the text scrolling up it covers). Installation of the live versions was very quick!
All installs were done from ROM keys written by the Mepis System program in the betas. That is a good program for making M12 keys (it won't do other distros). And, of course, I checked the MD5 of the downloaded files first.
MAIN: AMD Athlon II 270 64-bit dual core; 3400mhz; 4 gig RAM; nVidia; 1600x900; 1 Hard disk, 459gb
BACK(up): AMD Athlon II 250 64-bit dual core; 3000mhz; 4 gig RAM; nVldla; 1600x900; 1 Hard disk, 466gb
Wireless network
Wireless network
Re: M12 11.9.92
Well, 11.9.91 suddenly went bottom up (not encouraging), so I burned a DVD of this one and installed it. install all OK, though still hangs on exit from minstall, and reboot dumped me at a login prompt though LiveDVD did fine. I installed sgfxi and an Nvidia driver.
As with 11.9.91, the new driver seems to block plymouth somehow, so I get a minimal Debian screen during boot.
Re: M12 11.9.92
To get the Mepis 12 plymouth splash to show up when the proprietary nvidia driver is installed, I need to add the vga=xxx cheatcode (vga=791 in my case).Jerry3904 wrote:... I installed sgfxi and an Nvidia driver.
Edit the /etc/default/grub file and add the vga=xxx cheat to either the GRUB_CMDLINE_LINUX or GRUB_CMDLINE_LINUX_DEFAULT line. Run update-grub afterward.
