-- Change in MX sources
-- antiX-17 release info here
having problems connecting to LinuxTracker
This forum is for co-ordination of torrents for MEPIS releases
kesuda
#1 Post by kesuda » Sun Jan 22, 2012 4:56 pm
with excessively long page loads (if they load at all).
I've checked to make sure I wasn't just running the router or firewall too tight (again).
At first I thought they were having issues at their end, but my torrents seem to be running fine.
Anyone else having troubles connecting?
joany
Re: having problems connecting to LinuxTracker
#2 Post by joany » Sun Jan 22, 2012 5:27 pm
I'm having the same result here.
The connection has timed out
The server at linuxtracker.org is taking too long to respond.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer's network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
The site is probably just experiencing a temporary problem.
2.4GHz AMD Athlon 4600+
lucky9
#3 Post by lucky9 » Sun Jan 22, 2012 5:47 pm
That happens occasionally there.
--Mark Twain
kapookee
#4 Post by kapookee » Sun Jan 22, 2012 6:31 pm
kesuda wrote: Anyone else having troubles connecting?
Yep. It pings okay, but the website won't come up. (5:30 pm EST)
Laptop: Compaq Presario 2.2 GHz Celeron 64 bit 2 Gb RAM Intel Graphics Atheros AR9285
Desktp1: ASUS M2NBP-VM CSM AMD Athlon 64 X2 3800+ 2.0 GHz 3 Gb RAM GeForce 9800 GT
Desktp2: Dell Optiplex GX620 Intel P4 64 X2 3.6 GHz 4 Gb RAM Intel graphics
Paul..
#5 Post by Paul.. » Sun Jan 22, 2012 8:44 pm
Same here...will not load...19:44 Eastern time...
Asus Prime X470-Pro
AMD Ryzen 5 1400 (8 threads)
16 Gig DDR4 3000
Nvidia - GeForce GTX 750 Ti
Samsung 970 NVMe SSD nvme0n1P2=MX-18
500GB SSD sda1= Data
lucky9
#6 Post by lucky9 » Mon Jan 23, 2012 2:23 am
I got an email a few days ago about a contest in Feb. The site is still down at this time.
--Mark Twain
ceandrewk
#7 Post by ceandrewk » Wed Jan 25, 2012 9:39 pm
None of my torrents seem to be working - all show Status as Seeding with the error symbol and "Error: Invalid response from tracker" on the tracker tab in KTorrent 4.0.2.
The web site is most always relatively slow to load - seems normal today, but a couple of days ago when I first noticed the problem, the web site would eventually load, but would time out more often than it would load.
Anyhow, I have deleted a couple of the torrents, downloaded and re-started them, with the same error.
Any help or suggestions where to look to solve this problem will be greatly appreciated.
Paul..
#8 Post by Paul.. » Wed Jan 25, 2012 10:55 pm
Linuxtracker is behaving tonight
--- linuxtracker.org ping statistics ---
19 packets transmitted, 19 received, 0% packet loss, time 18023ms
rtt min/avg/max/mdev = 72.075/74.522/81.947/2.251 ms
...but even when it was slow and unreachable via http these past few days, I did not get the error you are seeing...using Deluge 1.3.1
Are you still getting the errors now that the site is back to reasonable performance?
Asus Prime X470-Pro
16 Gig DDR4 3000
Paul..
#9 Post by Paul.. » Wed Jan 25, 2012 10:58 pm
ceandrewk wrote:None of my torrents seem to be working - all show Status as Seeding with the error symbol and "Error: Invalid response from tracker" on the tracker tab in KTorrent 4.0.2.
Check this thread...seems to be a known problem that has a workaround...http://ktorrent.org/forum/viewtopic.php ... aad#p17001
Asus Prime X470-Pro
16 Gig DDR4 3000
joany
#10 Post by joany » Thu Jan 26, 2012 9:41 am
Linux Tracker is back up as of 1/26/12.
Return to “Torrent Team”
