Just a comment. My dictionary refers to as torrent as fast moving. My torrent system is currently uploading slowly to a potential antiX user in Sardinia.
Their bits per second upload speed here is usually in single digits. After several days of activity the total is just over 10%. Other users appear, upload,
and disappear with good speeds. This one must be saddled with a sensationally slow line.
Torrent reduced to a (very) slow drip
- Gordon Cooper
Re: Torrent reduced to a (very) slow drip
Dial-up, perhaps?
- Gordon Cooper
Looks as if they have abandoned it. The overnight uptake was about 0.5%, but shortly after 8am(local) the connection disappeared and has not returned.
Current Status: Our 2 Servers are each running opentracker + seeder
l2.mxrepo.com
peers 460
seeds 445
it.mxrepo.com
peers 348
seeds 335
Apart from the guy in Sardinia...how is it performing for you in NZ, Gordon?
l2.mxrepo.com
peers 460
seeds 445
it.mxrepo.com
peers 348
seeds 335
Samsung 860 500GB SSDs (2)
- Gordon Cooper
Hi Paul, generally the performance is good and I have very few problems since we changed over to Theo's servers. Occasionally, as happened with Pale Moon this week
we miss an MX upgrade because of Time differences but that is not a issue for me and the upgrade will be there the next day. Am helped too by all of this part of
town changing to glass fibre quite early in the NZ project. It is fast and reliable. The torrents just keep going and if the very occasional power failure does happen, I can run the gear from a solar charged backup supply.
