FYI... here are some clues to 4.14 of xfce
https://bluesabre.org/2019/04/18/xubunt ... ve-update/
xfce 4.14 update
xfce 4.14 update
Re: xfce 4.14 update
That little tour did nothing but discourage me about xubuntu. No room in my life for bleeding edge baloney.
(I wasn't considering it anyway. That bridge was long ago burned.)
Xfce isn't exactly famous for "bleeding edge baloney" though. It's development has been very slow and deliberate. As for Xubuntu, I think it's great and better yet because it's truly a community distro where users and devs all have some input. But it's Ubuntu-based, so I would only use LTS editions, and even then I would have reservations because of updates from Ubuntu.
I have to say... I personally like bleeding edge baloney. :lipsrsealed: I think it's pretty good with lettuce, mustard and rye.
I installed it.
Good things:
Xfce
systemd behaved well
GTK3 rendering bug has been fixed
kernel 5 without problems
Bad things:
The repos were missing good stuff that are present in Debian Stretch (this is basically Debian Testing)
Snaps are pushed everywhere
(ugly) Plymouth (think Windows 10)
Installer slow
many GTK3 (3.24) themes are slightly unfinished because it takes a long time to polish a theme
Crazy things:
MATE desktop is offered with experimental Wayland session with Mir compositor installable as Snap
Overall better than expected, but I really worry about the future of Linux... Despite the rapid change of Windows 10 there is much more "plumbing" done in Linux distros. It's like a war against diversity... I think Stretch might be the last release where all the old tools are present.
Good things:
Xfce
Bad things:
Installer slow
Crazy things:
@dreamer, we may need to go and hide in environments like Openbox. fluxbox, icewm etc.
I think you may have wandered into a degree of fervor that could prove dangerous...
I have xfce 4.13+ (gtk3) on my manjaro install on my laptop.
Pretty often, an update will mess with the Xfce desktop's theming.
That makes thunar-gtk3, logout dialogue window, and some elements of the Xfce panel ignore my icon, theme and font settings, and revert to gnome/adwaita icons and default font size (which is tiny on my hidpi screen).
The window manager theme is unaffected, and the rest of the apps and windows don't have that problem.
Sometimes a reboot will sort it out while other times only the next series of updates will.
I suppose it's because Manjaro is actively rolling all the little updates in the development of 4.13+ on its way to the end goal of 4.14 , but it's not finished yet.
The difference is that xubuntu takes just a snapshot of xfce 4.13 at a particular point in its development, so they probably chose a point where everything in the default xubuntu setup was working.
Oops, forgot that since Manjaro is rolling, the regular updates of gtk3 and gnome elements might probably affect xfce-gtk3 as well. That likely contributes to the problems as xfce 4.13 continues its development.
Each Xubuntu release will be built on a fixed gtk3 version.
