Seems like a good deal to me if you need to upgrade from spinning HDD:
https://www.amazon.com/Kingston-120GB-S ... 0S37-120G/
There are cheaper such as adata, but, since I don't know anything about that company I would stay away.
120GB SSD for 18$ or 240GB for 30$ - Kingston
- Buck Fankers
- chrispop99
- Global Moderator
Re: 120GB SSD for 18$ or 240GB for 30$ - Kingston
Adata are good budget drives, with decent reviews, so if you found one at a bargain price you shouldn't be put off.
The link you posted 404's for me.
DELL XPS 15
Lots of test machines
DELL XPS 15
A quick search of Amazon produced this
which shows the 120GB for $17.99USD, the 240GB for $29.99USD, and the 480GB for $59USD.
AsusTek PRIME B450-Plus
Samsung SSD 860 EVO 500GB
DDR4 3200MHz CL16 2x8GB
Yes, yes, yes. There's no reason to run rotational HDDs for your system if you have $17. It's a great improvement. You can keep HDDs as a secondary drives for data if needed (or backups), but 120GB should be plenty for a root Linux partition. I used Kingston and Adata interchangeably, didn't see a difference in speed or reliability. The difference that you'll see will be between HDD and SSD.
If people are unfamiliar with failure predictions for various storage devices, here's a nicely organized article on the topic of reliability.
https://www.wepc.com/tips/ssd-reliability/
No problem when moving large files? From what I understand, cheaper ssd are often if not always without Dram. Which mean they may be slower in some cases and last shorter (generally shorter warranty period).Adrian wrote: ↑Tue Feb 05, 2019 11:25 am Yes, yes, yes. There's no reason to run rotational HDDs for your system if you have $17. It's a great improvement. You can keep HDDs as a secondary drives for data if needed (or backups), but 120GB should be plenty for a root Linux partition. I used Kingston and Adata interchangeably, didn't see a difference in speed or reliability. The difference that you'll see will be between HDD and SSD.
Very convenient in most situations but it seems samsung evo 860 and crucial MX500 are a better bet with a slightely higher price.
Your opinion?
My opinion is that you get what you pay for, but the larger difference is between HDD and SSD, not between SSD and SSD (generally speaking, it might not be true in some particular cases) so if you can afford a better SSD, yeah sure, but if you want to spend only $17 to improve the performance of your computer significantly, you can do it.
Yes, not all SSD's are equal. I have had great results with both Kingston and Adata, but I do prefer Samsung Evo's.cyrilus31 wrote: ↑Tue Feb 05, 2019 12:08 pmNo problem when moving large files? From what I understand, cheaper ssd are often if not always without Dram. Which mean they may be slower in some cases and last shorter (generally shorter warranty period).Adrian wrote: ↑Tue Feb 05, 2019 11:25 am Yes, yes, yes. There's no reason to run rotational HDDs for your system if you have $17. It's a great improvement. You can keep HDDs as a secondary drives for data if needed (or backups), but 120GB should be plenty for a root Linux partition. I used Kingston and Adata interchangeably, didn't see a difference in speed or reliability. The difference that you'll see will be between HDD and SSD.
Your opinion?
MX Linux Asus F552, 12GB RAM, 500GB WD SSD MX19.2
Dell Inspiron 7559 16GB RAM 1X 256GB SSD & 1TB SSD MX KDE 21.1 & Windows 11
Mini Tower PC 2X 256GB SSD MX KDE21.1
In any case there are no Evo nor MX500 with less than 250Go of memory. You have the cheaper BX family with 120Go. From what I see, If you want 120Go there are only dramless ssd (A400 or Adata SSD). From 500Go on, the price difference is about 10€ max between DRAm ssd and dramless ones (there are often discounts).
For 120Go Kingston A400 is a good choice.
I have had good luck with the Dogfish brand out of Hong Kong (where they are fabricated,apparently). Marketed by Newegg, among others. At least with a 32GB SSD that I slapped into an Acer Atom n270 based netbook, and a 128GB mSATA that I put into an Intel 180GB SSD equipped Lenovo T430, as an extra SSD.
