I've checked a couple sources and the general process I've found is to:
1-use gparted to format the usb device to fat32
2-Use unetbootin to put a FREEDos image/files on the same usb device.
After this, I should be able to boot from the thumb-drive.
I used a 2G thumb-drive and even set its boot flag.
My laptop wouldn't boot from the device after following the above steps.
more to follow.
- mike
How to create a DOS bootable usb thumb-drive
- mmikeinsantarosa
Re: How to create a DOS bootable usb thumb-drive
MX 18 MX 19 - Manjaro
- mmikeinsantarosa
Correct-a-mundo. formatting to fat16 solves the problem.
Could have sworn I tested both 32 & 16.
At least there's a look-up here now.
this reference might be userful for ya: https://www.plop.at/en/bootmanager/plpbt.bin.html
