Some stubborn holdouts with that old EOL distro asked for Pale Moon 28 debs, and it only has gcc-4.8 when PM now requires at least 4.9. I wasn't able to build an newer gcc successfully for Trusty in my OBS repo, so I when I found a PPA that had newer gcc versions, I created a 64-bit 14.04 VM, added the PPA, and successfully built and tested PM with gcc-5 from the PPA.
However, when I tried running the Xubuntu, Lubuntu, Ubuntu, and Mint 17.3 XFCE 32-bit ISOs to do the same in a 32-bit PAE VM, they all fail to boot after the initial screens after some minutes without disk activity by falling back to a busybox CLI and a message about not finding a bootable medium.
This is with Vbox 5.2.18 on 64-bit MX 17.1. 32-bit MX ISOs have no problems with the same VM.
Is there a simple, well known fix for this issue that I'm missing, or can anyone reproduce the issue?
[SOLVED] Can't get any Ubuntu 14.04 32-bit to run in Virtual Box
Re: Can't get any Ubuntu 14.04 32-bit to run in Virtual Box
Hmm.., not sure I understand, are you saying you cannot boot at all, the 32bit trusty version ,Stevo wrote: ↑Tue Aug 21, 2018 1:28 pm ..
or you can not boot just on a 32bit emulated OS in VirtualBox the 32bit trusty iso.
I have just booted ubuntu-14.04.5-desktop-i386.iso
with in these VM's without any issue:
VirtualBox 64bit OS-emulation
VirtualBox 32bit/PAE OS-emulation
KVM/Qemu 32bit/PAE OS-emulation
KVM/Qemu 64bit OS-emulation
--fehlix
Yes, I'm wondering if it's some kind of bug in Virtual Box 5.2.18. I can't test a boot on my laptop's real hardware because 14.04 is far too old to support it. I set up a 32-bit PAE virtual machine, the same I have done many times before, but now those (and I tested the Elementary OS ISO based on 14.04 since) apparently can see the ISO I've attatched, since I can see the first menu or so, but then they just stop reading it.
Just booted again within VirtualBox 5.2.18 PAE/32bit-emulatedStevo wrote: ↑Tue Aug 21, 2018 5:32 pm Yes, I'm wondering if it's some kind of bug in Virtual Box 5.2.18. I can't test a boot on my laptop's real hardware because 14.04 is far too old to support it. I set up a 32-bit PAE virtual machine, the same I have done many times before, but now those (and I tested the Elementary OS ISO based on 14.04 since) apparently can see the ISO I've attatched, since I can see the first menu or so, but then they just stop reading it.
another xubuntu-14.0.5.desktop-i386.iso, without an issue.
Can you turn of splash, (I think press F6 to edit the kernel options within xubuntu based menu),
to see something messages?
Hey, the F6 got it to boot--installing now!
Ahh, a key issue ;=) ... to show the bootmenu, just press arrow-up or arrow-down
