Partially OT - parted -l equivalent without sudo
Buck Fankers
#1 Post by Buck Fankers »
Didn't see Off Topic forum, hope this is OK to ask here
I'm looking for equivalent of this command:
parted -l | grep "Partition Table: "
That does not need sudo.
I wrote a small python script in Manjaro, that i'm now porting here to MX, that check few logs for keywords such as "error', "failed"... and few other things. One of them is to check if OS is properly installed such as that partition table matches bios setting like this: BIOS+msdos or UEFI+gpt
I can check how is BIOS set with:
test -d /sys/firmware/efi && echo UEFI || echo BIOS
But this one will not return anything unless I run it with sudo:
Since it is bad sport to toss around to others code that ask for password, :-) I would rather have non sudo equivalent if it is possible. Anyone happen to knows what could I use instead of <parted -l | grep "Partition Table: ">?
Re: Partially OT - parted -l equivalent without sudo
#2 Post by dolphin_oracle »
I don't know if this will do quite what you want but
udevadm info /dev/sda |grep ID_PART_TABLE_TYPE
will output a partition table type. you have to call each device though.
Buck Fankers
#3 Post by Buck Fankers »
That works, thanks.
Do you happen to know, what exact info it returns on EFI machines?
Maybe:
ID_PART_TABLE_TYPE=efi
Can't test it, my computers are old ;-)
#4 Post by dolphin_oracle »
well, efi is not a partition type, so it won't return anything.
what do you actually want to know?
this will tell you the Partition type of each partition
lsblk -o NAME,LABEL,PARTTYPE
with output like
NAME   LABEL           PARTTYPE
sda
├─sda1 SYSTEM_DRV      c12a7328-f81f-11d2-ba4b-00a0c93ec93b
├─sda2                 e3c9e316-0b5c-4db8-817d-f92df00215ae
├─sda3 Windows7_OS     ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
├─sda4 Lenovo_Recovery ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
├─sda5 rootMX17        44479540-f297-41b2-9af7-d131d5f0458a
├─sda6 datapart        ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
├─sda7                 0657fd6d-a4ab-43c4-84e5-0933c84b4f4f
├─sda8 rootMX17        44479540-f297-41b2-9af7-d131d5f0458a
└─sda9 dataext         0fc63daf-8483-4772-8e79-3d69d8477de4
sr0
note on my sda1 partition this string
that is the GUID itentifier for ESP partitions, which are the partitions where efi stub files are stored for UEFI booting.
Good reading here: https://en.wikipedia.org/wiki/GUID_Partition_Table
Buck Fankers
#5 Post by Buck Fankers »
On Manjaro, if you miss match installations, say you install it msdos + UEFI or BIOS + gpt, one of this combo will (or can) cause a problem. Some users managed to get this wrong and I have a noob script that check few things, check logs for errors, check this combo to see if install is correct. On Debian may not be the same. To check I run these two commands:
test -d /sys/firmware/efi && echo UEFI || echo BIOS'
If output is one of these two pairs: BIOS+msdos or UEFI+gpt all is OK, otherwise there can be a problems.
On Manjaro i could run second command without sudo, so i could just put it into script. Here it requires SUDO, because of this I'm looking for alternatives, which you gave me. All I need is to know what it returns on newer, modern systems.
But maybe this whole check is not needed on MX systems anyway? I'm quite fresh in Linux world and me doing something silly is usually a norm ;)
#6 Post by dolphin_oracle »
gotcha
#7 Post by asqwerth »
Buck Fankers wrote:On Manjaro, if you miss match installations, say you install it msdos + UEFI or BIOS + gpt, one of this combo will (or can) cause a problem. Some users managed to get this wrong...
If output is one of these two pairs: BIOS+msdos or UEFI+gpt all is OK, otherwise there can be a problems. ...
Hmm. My Manjaro install:
1. has the honour of being controlling grub on the MBR of the msdos-formatted /dev/sda (ie, BIOS setting is legacy boot)
2. is itself installed on a partition in gpt-formatted /dev/sdb
I don't recall having problems installing it in 2015.
Buck Fankers
#8 Post by Buck Fankers »
asqwerth wrote: Hmm. My Manjaro install:
Well, I never said, problem is guaranteed :p
Sometimes, when community was troubleshooting someones problem, this occasionally appeared as the culprit and it is generally not advised for beginner members.
Similarly with boot customizer. Occasionally it would cause the problem, although many said, works OK with me. Enough to suggest beginners to stay away from potential problems.
Back to original subject, I don't know if it is the same case for Debian or MX. But that script is just my little project, trying to learn some basic in Linux and working on my first baby steps in Python programming.
Anyone with EFI system could you show me, what is the output of this command:
#9 Post by richb »
$ udevadm info /dev/sda |grep ID_PART_TABLE_TYPE
E: ID_PART_TABLE_TYPE=gpt
And for /sdd:
udevadm info /dev/sdd |grep ID_PART_TABLE_TYPE
E: ID_PART_TABLE_TYPE=dos
Buck Fankers
#10 Post by Buck Fankers »
richb wrote: E: ID_PART_TABLE_TYPE=gpt
I got the 'dos' on my old system, but could not check the output for gpt/uefi.
