Ocenaudio: Request
manyroads
Ocenaudio: Request
#1 Post by manyroads »
Is it possible to have ocenaudio 3.6 added to the TestRepos? It may be found here: http://www.ocenaudio.com/download
Re: Ocenaudio: Request
#2 Post by timkb4cq »
No.
The source code is not available, and the license does not authorize distribution.
manyroads
#3 Post by manyroads »
timkb4cq wrote: Tue Mar 19, 2019 10:23 am No.
Thanks for checking.
nathan2423
#4 Post by nathan2423 »
Manyroads did you get one of the downloads to work? In 18.3 I am getting "ocenaudio: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory"
I generally try to use Audacity but I heard OcenAudio being recommended on DestinationLinux podcast and I'd like to try it.
sunrat
#5 Post by sunrat »
OcenAudio works fine for me just installing the .deb file from their website (on Debian, haven't installed it on MX). I'm not convinced it's any better than Audacity but the GUI is prettier.
Does your system actually have that libssl file?
Also make sure you download the file for Debian 9 as that's what MX is based on.
nathan2423
#6 Post by nathan2423 »
Well duh, yesterday I downloaded what I thought was the same file and it didn't work, but today I redownloaded and the file was incremented by 1 in the version number, and it worked. Thanks sunrat!
