Update Quodlibet to 4.02 (Solved)
The version in your repo quodlibet 3.7.1-2 would it be possible to update it to quodlibet 4.0.2 ....
Main : MX 19.1-AHS (i3) 5.4.13-1~mx19+1, Asus B450-i AMD 5 3600 , 32gb Hyper-X 3200 , GTX970 .
Re: Update Quodlibet to 4.02
I'll take a look at it. It's only possible for MX 17, though, not 15 or 16.
Edit: Done, it installs and runs on my system. It's uploading now for the test repository. You can install it and exfalso directly from the debs also from the zip: https://drive.google.com/open?id=1sL3Fu ... Fsz_9HGOWJ
@Stevo
Thanks was missing the new features of the newer version. Installed
