Telegram
catalinux
Telegram
#1 Post by catalinux »
Could you add Telegram to the repo, please? I tried to install it but I can only run it with sudo.
Acer Aspire One D260
Lately got a Lenovo V110-15ISK too
Re: Telegram
#2 Post by Jerry3904 »
It's available for MX-16.x at least:
$ apt-cache policy telegram
telegram:
  Installed: (none)
  Candidate: 0.9.44-0mx150+1
  Version table:
     0.9.44-0mx150+1 0
        500 http://mxrepo.com/mx/testrepo/ mx15/test amd64 Packages
It's in Debian Stretch-Backports so you should be able to get it for MX-17 as well using Package Installer.
catalinux
Re: Telegram
#3 Post by catalinux »
Found it. Apparently I wasn't checking the right repo :D
Later edit: you should upgrade it more often though. I am now downloading hundreds of megabytes of updates since it is not even on version 1 in the repo (don't wanna think what will happen next year when I'll buy a new computer)
Re: Telegram
#4 Post by Stevo »
I'll take a look at seeing if the newer version in Stretch-backports will build in MX 15/16.
Edit...no, it needs a newer Qt 5 than 15/16 has, but I ported it over to the MX 17 repo.
catalinux
Re: Telegram
#5 Post by catalinux »
thanks
catalinux
Re: Telegram
#6 Post by catalinux »
Thanks again. I just went back to see the status of it. Anyway, another curiosity of mine: will LibreOffice be updated to at least version 5.3 for MX 16? I'd really love to get that notebook bar on it
Re: Telegram
#7 Post by Jerry3904 »
You know you can do it yourself pretty easily:
  • go to the download site
  • Select the version you want (e.g., x64 deb) and click to download
  • when it has finished, open the Downloads folder and right-click the downloaded file > extract here
  • enter the folder that is extracted, the right-click the DEBS folder > open terminal here
  • enter the command
    dpkg -i *.deb
  • when it has finished, try to launch--may have to logout/login first
I do this all the time b/c I like and need the most recent stable version for business work.
Richard
Re: Telegram
#8 Post by Richard »
LibO-5.4.3-x86 from LibreOffice.org
works fine on my 32 bit AA1 netbook.
nanoSYS
Re: Telegram
#9 Post by nanoSYS »
@ catalinux
You can always download LibreOffice AppImages, they work quite well on MX16.1.
http://libreoffice.soluzioniopen.com/
Even try the latest LibreOffice daily 6.1.0.0 alpha0 @ http://libreoffice.soluzioniopen.com/in ... y-version/
This is the guy behind those AppImages:
https://github.com/antoniofaccioli
Cheers!
catalinux
Re: Telegram
#10 Post by catalinux »
I got the deb version and managed to get it working. As for Telegram, I signed myself out from my phone, uninstalled the old version from the repo, redownloaded the archive from their official website but this time I started Telegram right after unpacking. Then I did all that /opt moving, symlinking and I got th latest version working without using sudo in the terminal.
I might upgrade to MX 17 soon though.
Thank you all for your help. keep up the good work! cheers!
