Seems like it might be a useful addition for us (it's GPL-3+)?Xubuntu 15.10 “Wily Werewolf” introduces a new application for managing panel layouts in Xfce, Xfce Panel Switch. This is a simple utility application that fills a void for appearance tweakers and distributors alike.
Features
Backup and restore panel configurations
Share panel layouts with simple exporting and importing
Choose from one of 5 included layouts, or install layouts system-wide in /usr/share/xfpanel-switch/layouts
Xfce Panel Switch
Xfce Panel Switch
This was developed by the Xubuntu folks, and looks pretty nifty. I downloaded the version for Ubuntu 16.04 and it installed without problem in MX-16.
Re: Xfce Panel Switch
how does it work with our orientation app?
No clue, just installed it to see if it worked after reading a post on the Google + Xfce site. Maybe it would be redundant...
It's different combos of both top and bottom horizontal panels, based on a Youtube video I just watched. No option to switch between vertical and horizontal layouts.
I like the ability to save and transfer configs easily, and wonder if we could eventually merge it with our existing app.
when you change layouts, does it preserve the custom launchers and plugins, or does it reset the config?asqwerth wrote:It's different combos of both top and bottom horizontal panels, based on a Youtube video I just watched. No option to switch between vertical and horizontal layouts.
From what I saw, it can save any configuration and restore it as it was. A detailed look will have to wait until after work...
https://www.youtube.com/watch?v=L8pwWN-6Cr0
I can't tell from the video. I'm guessing that because each layout they give you is different, like having a dock (2nd panel) at the bottom or not, it doesn't preserve your configs across the layouts but you can save your configs for a particular layout and restore that when you choose than layout again.
Took a quick look. I saved my current layout, then clicked on the Gnome layout and it was instantly there. When I went back to my saved layout, all was good except that a separator at the top above the clock was changed into a expand and filled the top quarter of the panel.dolphin_oracle wrote:when you change layouts, does it preserve the custom launchers and plugins, or does it reset the config?asqwerth wrote:It's different combos of both top and bottom horizontal panels, based on a Youtube video I just watched. No option to switch between vertical and horizontal layouts.
I do see some potential though, and will keep looking at it.
