fbreader upgrade fails [solved]
#1 Post by Jerry3904 »
On fully upgraded MX-16 64bit, this error shows:
(synaptic:22651): GLib-CRITICAL **: g_child_watch_add_full: assertion 'pid > 0' failed
(Reading database ... 260518 files and directories currently installed.)
Preparing to unpack .../fbreader_0.99.4-1mx15+1_amd64.deb ...
Unpacking fbreader (0.99.4-1mx15+1) over (0.12.10dfsg-9.1+b1) ...
dpkg: error processing archive /var/cache/apt/archives/fbreader_0.99.4-1mx15+1_amd64.deb (--unpack):
 trying to overwrite '/usr/share/zlibrary/encodings/ISO-8859-16', which is also in package libzlcore-data 0.12.10dfsg-9.1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for menu (2.1.47) ...
E: Sub-process /usr/bin/dpkg returned an error code (1)
A package failed to install.  Trying to recover:
Re: fbreader upgrade fails
#2 Post by Stevo »
Whoops--I did not realize that Debian had split the older fbreader into several separate packages--I'll see if I can do the same with the new one. In the meantime, you should be able to install the new one if libzlcore-data is removed first.
apt remove libzlcore-data
apt-get autoremove
apt install fbreader
#3 Post by Jerry3904 »
OK, thanks. I'm not on that machine ATM, but will try it tonight.
smilliken
#4 Post by smilliken »
Stevo wrote:Whoops--I did not realize that Debian had split the older fbreader into several separate packages--I'll see if I can do the same with the new one. In the meantime, you should be able to install the new one if libzlcore-data is removed first.
apt-get autoremove
still lots of errors trying to do the
There is no "Ctrl+Z" in life!
Asus X570, Rysen 3600, 32 GB RAM MX-21
Acer 7551G MX-21 & Win 10
Asus i5, 16 GB RAM MX-21 & Win 10
Brother DCP-7065DN/HL-L3270CDW
Linux User# 4523410
#5 Post by Stevo »
apt-get autoremove
Can you cut and paste those errors in a code box here? The command should remove the older fbreader and some other packages that are part of it, but that's what I intend.
smilliken
#6 Post by smilliken »
sudo apt remove libzlcore-data
Reading package lists... Done
Building dependency tree
The following package was automatically installed and is no longer required:
  libzltext-data
Use 'apt-get autoremove' to remove it.
The following extra packages will be installed:
  fbreader
The following packages will be REMOVED:
  libzlcore-data libzlcore0.12 libzltext0.12 libzlui-qt4
  fbreader
1 upgraded, 0 newly installed, 4 to remove and 0 not upgraded.
Need to get 0 B/2,035 kB of archives.
After this operation, 1,366 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 195831 files and directories currently installed.)
Linux User# 4523410
#7 Post by Jerry3904 »
That first command fails:
root@hp6930p:/home/jb# apt remove libzlcore-data
  libzltext-data
  fbreader
  fbreader
#8 Post by Stevo »
Try uninstalling fbreader first, then.
Anyway, installing the first single deb fbreader 0.99.4 update I did will also cause complications with the multipart one I'm finishing up--but if that's installed, just uninstalling it will get rid of everything. We need to see how the new multipart one will upgrade over the stock Jessie one once it's in the repo--it took quite a bit of tweaking in the rules files to get it to build correctly.
Edit: anyway, this command should get back to the Debian version (remember that aptitude can present several solutions, read the output carefully and hit "n" to go to the next one)
sudo aptitude install fbreader=0.12.10dfsg-9.1+b1
#9 Post by Jerry3904 »
OK, that cleared out apt notifier. Anything besides uninstalling for now?
#10 Post by Stevo »
Well, I just threw it the new version into one of my existing OBS repos so I can test how it upgrades over the old Jessie version in a few minutes. I have the new MX version built, but it needs at least five or six packages instead of one, so I am not eager to list all the instructions on how to install them manually; I'd rather let the apt system just do it automagically.
