Freemind
Freemind
http://freemind.sourceforge.net/wiki/in ... /Main_Page
Couple of version higher than the 0.9.0 in the repos. I realize these are in a beta, but I would give it ago.
Thanks
Scott
Thanks
Scott
There is no "Ctrl+Z" in life!
Asus X570, Rysen 3600, 32 GB RAM MX-21
Acer 7551G MX-21 & Win 10
Asus i5, 16 GB RAM MX-21 & Win 10
Brother DCP-7065DN/HL-L3270CDW
Linux User# 4523410
Linux User# 4523410
Re: Freemind
There's no problem rebuilding the stable 1.0.1 version from the sources at Getdeb, but the patches for that version fail to apply to the newer 1.1.0 beta 2 source, so the build fails. I'll send up the stable version--have you tried to manually run their beta version per the instructions they provide?
Re: Freemind
Not yet. Just saw it was available. Can give it a go after work.
Thanks Stevo
Thanks Stevo
Linux User# 4523410
Linux User# 4523410
Re: Freemind
Downloaded and installed "ant" as per the readme.txt. When I try to run the program, there are a lot of java errors that are spilled on the screen.
The same the other 2 listed in the readme.txt. I've tried it with both sudo and not. Can't be that hard, must have missed something.
ant dist
BUILD FAILED
/home/scott/Downloads/freemind/build.xml:87: Execute failed: java.io.IOException: Cannot run program "/home/scott/Downloads/freemind/check_for_duplicate_resources.sh": error=13, Permission denied
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1047)
at java.lang.Runtime.exec(Runtime.java:617)
at org.apache.tools.ant.taskdefs.launcher.Java13CommandLauncher.exec(Java13CommandLauncher.java:58)
at org.apache.tools.ant.taskdefs.Execute.launch(Execute.java:428)
at org.apache.tools.ant.taskdefs.Execute.execute(Execute.java:442)
at org.apache.tools.ant.taskdefs.ExecTask.runExecute(ExecTask.java:628)
at org.apache.tools.ant.taskdefs.ExecTask.runExec(ExecTask.java:669)
at org.apache.tools.ant.taskdefs.ExecTask.execute(ExecTask.java:495)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:435)
at org.apache.tools.ant.Target.performTasks(Target.java:456)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1393)
at org.apache.tools.ant.Project.executeTarget(Project.java:1364)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1248)
at org.apache.tools.ant.Main.runBuild(Main.java:851)
at org.apache.tools.ant.Main.startAnt(Main.java:235)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:280)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:109)
Caused by: java.io.IOException: error=13, Permission denied
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:187)
at java.lang.ProcessImpl.start(ProcessImpl.java:130)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1028)
... 23 more
Linux User# 4523410
Linux User# 4523410
Re: Freemind
found one of the script files was not made to be executeable, run the ant command, the program appears to build, still no joy in getting it to run.
Linux User# 4523410
Linux User# 4523410
- mmikeinsantarosa
Re: Freemind
I got the 1.1.0 beta 2 source to build and install but it won't run in a vm.
Re: Freemind
scratch that, somehow I got it run. Not ideal, both 0.9.0 and the 1.1.0 are on the computer in two different areas.
thanks
thanks
Linux User# 4523410
Linux User# 4523410
Re: Freemind
Got it. Many thanks!mmikeinsantarosa wrote:I got the 1.1.0 beta 2 source to build and install but it won't run in a vm.
Linux User# 4523410
Linux User# 4523410
Re: Freemind
Did you just dump all the patches?mmikeinsantarosa wrote:I got the 1.1.0 beta 2 source to build and install but it won't run in a vm.
- mmikeinsantarosa
Re: Freemind
No,
Doing a dpkg-source with the 1.0.1 version sticks a .pc folder at the debian level. I lifted said .pc folder and stuck it in with the 1.1.0 beta 2 extracted source folder and created a new orig.tar.xz from that wad then stuck the 1.0.1 debian folder in with the 1.1.0 source, updated the stanza to 1.1.0 and it built.
