Skype 4.3.0.37-1skype: symbol lookup error: /usr/lib/i386-linux-gnu/libQtOpenGL.so.4: undefined symbol: _ZNK14QWidgetPrivate17hasHeightForWidthEv
skype error on 64bit MX-15 [solved]
I installed Skype with MX Package Installer then when I try to run it I get this:
Re: skype error on 64bit MX-15
No such problem on my 64-bit installation.
I got no errors as well. however, this message has some google hits. this looked promising.
http://askubuntu.com/questions/450784/s ... ned-symbol
That's an old thread and refers to an old skype version which was disabled by Microsoft.
yes, but the mesa info may still be valid.
Thanks for the help, forgot to report, this fixed the problem:
Exec=env LD_LIBRARY_PATH=/usr/lib/i386-linux-gnu/ /usr/bin/skype
Re: skype error on 64bit MX-15 [solved]
I don't really need to know this since I have not (yet) experienced the problem, but do I
gather you have worked around it by editing the "Exec= ......" line in the skype.desktop file?
Do you know why you had the problem when others have not?
It might be because I use Qt5 to build apps, maybe it has something to do with how the libraries get set up.
Thanks, Adrian.
(I do miss the old "thankyou" button!)
David.
David.
