pandoc [Solved]
Gordon Cooper
pandoc [Solved]
#1 Post by Gordon Cooper »
Would be grateful for a pandoc update. Latest version is pandoc 1.17.1 (4 Jun 2016). Think that our repo version is several years earlier. (Hoping to use this in manual translations)
v3g4n
Re: pandoc
#2 Post by v3g4n »
Working on it, but it will take a bit. There are around 17 packages that will need to be backported in order for it to even build. :footinmouth: I hope you are really going to use it because that is alot for one package. :p
Re: pandoc
#3 Post by Jerry3904 »
Gordon, can you confirm that it is actually worth his time?
v3g4n
Re: pandoc
#4 Post by v3g4n »
If it will help the team with documentation, I have no problem packaging it. I just didn't want to spend the hours packaging it and it turns out it wasn't really that useful, that's all.
Re: pandoc
#5 Post by Jerry3904 »
It's worth a check on our part, and I think you guys need to be asking that question...
v3g4n
Re: pandoc
#6 Post by v3g4n »
Sorry, I'm giving up this one. Even the backports need more backports or changes made to the versions in the debian/control files. Maybe Tim, Mike or Stevo will know better how to port it with the least amount of effort.
Re: pandoc
#7 Post by Jerry3904 »
Thanks for looking at it, we completely understand.
Re: pandoc
#8 Post by Stevo »
The Pandoc home page has a 64-bit deb of the latest 1.17.1 version that is installable on MX 15, and the executable runs in the terminal on my system, so it seems there's some way to build it on our present Haskell. But if they've already provided it, I'm a bit reluctant to try and figure out that rat's nest of build-dependencies.
Re: pandoc
#9 Post by Jerry3904 »
Understood, and it makes sense to me.
lucky9
Re: pandoc
#10 Post by lucky9 »
Everybody is happy. Love it when that happens.
--Mark Twain
