Fritzing 0.9.2b
smilliken
Fritzing 0.9.2b
#1 Post by smilliken »
Fritzing is an open-source hardware initiative that makes electronics accessible as a creative material for anyone. We offer a software tool, a community website and services in the spirit of Processing and Arduino, fostering a creative ecosystem that allows users to document their prototypes, share them with others, teach electronics in a classroom, and layout and manufacture professional pcbs.
http://fritzing.org/home/
0.9.0b+dfsg-1 is in the repos, Wondering if this can be upgraded.
There is no "Ctrl+Z" in life!
Asus X570, Rysen 3600, 32 GB RAM MX-21
Acer 7551G MX-21 & Win 10
Asus i5, 16 GB RAM MX-21 & Win 10
Brother DCP-7065DN/HL-L3270CDW
Linux User# 4523410
v3g4n
Re: Fritzing 0.9.2b
#2 Post by v3g4n »
Unless someone else has time to do it before I get off work, I will take a gander at it tonight.
smilliken
Re: Fritzing 0.9.2b
#3 Post by smilliken »
Thanks
Linux User# 4523410
v3g4n
Re: Fritzing 0.9.2b
#4 Post by v3g4n »
packages are on the way the testing and should be there in the near future.
In the mean time here are the packages if you don't want to wait.
Install order is fritzing-data, fritzing-parts and then fritzing.
MX 15 packages
https://drive.google.com/file/d/0B_C2mB ... sp=sharing
MEPIS 12/MX 14 packages
smilliken
Re: Fritzing 0.9.2b
#5 Post by smilliken »
thanks again!
Linux User# 4523410
smilliken
Re: Fritzing 0.9.2b
#6 Post by smilliken »
Small problem when attempting to install.
dpkg: dependency problems prevent configuration of fritzing:
 fritzing depends on libqt5concurrent5 (>= 5.0.2); however:
  Package libqt5concurrent5 is not installed.
 fritzing depends on libqt5serialport5 (>= 5.1.0); however:
  Package libqt5serialport5 is not installed.
 fritzing depends on libqt5xml5 (>= 5.0.2); however:
  Package libqt5xml5 is not installed.
 fritzing depends on libqt5sql5-sqlite; however:
  Package libqt5sql5-sqlite is not installed.
dpkg: error processing package fritzing (--install):
 dependency problems - leaving unconfigured
Setting up fritzing-data (0.9.2b+dfsg-4mx150+1) ...
Setting up fritzing-parts (0.9.2b+dfsg2-1mx150+1) ...
Processing triggers for menu (2.1.47) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for desktop-file-utils (0.22-1) ...
Processing triggers for mime-support (3.58) ...
 fritzing
Linux User# 4523410
Re: Fritzing 0.9.2b
#7 Post by timkb4cq »
If this capture is from manually running sudo dpkg -i fritzing_0.9.2b+dfsg-4mx150+1_amd64.deb then you just need to sudo apt-get install -f to install those dependencies. dpkg doesn't automatically install dependencies. If you had clicked on them in a file manager it would have used gdebi instead, which does handle dependencies.
smilliken
Re: Fritzing 0.9.2b
#8 Post by smilliken »
Thanks Tim, Yes, that is how I was installing it. I did discover the repos for jesse were not loading, for some reason. Changed the default repo from "us" to "ca" and had the same results. They may have been down for maintenance last night, to sure. Will try it again now.
Whoops, same results
Linux User# 4523410
smilliken
Re: Fritzing 0.9.3b
#9 Post by smilliken »
I see 0.9.3b is now out. Not sure if it is out on the Debian sites.
Linux User# 4523410
v3g4n
Re: Fritzing 0.9.2b
#10 Post by v3g4n »
smilliken wrote:I see 0.9.3b is now out. Not sure if it is out on the Debian sites.
Debian seems to have split the source into two parts, one for fritzing and the other for fritzing-parts. I'm not exactly sure how to do it myself so as soon as I see a debianized package for it I will port it.
