Serious bug in Gdebi-kde 0.8.7 -- is there a later package?
I posted a question a short time back in another part of the Forum about Gdebi asking for a user password instead of the root password. I consider making changes to the root file system, such as installing software, with only user privileges is a serious bug and a security breach. I'm pretty sure that Gdebi required the root password in the past when installing software.
Anyway, the version currently available in the Wheezy repository is 0.8.7. There's a version 0.9.5.4 in the Sid repository.
1. Do others see the same behavior with Gdebi? If so, is this really a bug/security issue or am I just being paranoid?
2. Would version 0.9.5.4 fix the bug? Would it work with MX-14/Wheezy?
3. If 0.9.5.4 won't work, could the CR package wizards provide a version more recent than 0.8.7 that would?
4. If fixing Gdebi isn't possible, is there a different package installer that I could replace Gdebi with? I don't want to be able to install software under "admin" or user permissions on my system. I'm thinking about eDeb, which is currently not found in the repositories.
T.I.A.
T.I.A.
2.4GHz AMD Athlon 4600+
Re: Serious bug in Gdebi-kde 0.8.7 -- is there a later packa
Do you have kdesudo installed?
Yes. Should I remove it?kmathern wrote:Do you have kdesudo installed?
Only if it doesn't cause a bunch of other packages to be removed.joany wrote:Yes. Should I remove it?kmathern wrote:Do you have kdesudo installed?
If I recall correctly there might also be some changes you can make in the /usr/share/gdebi/GDebi/GDebiKDE.py file, we did that in the M8.5 and/or M11 gdebi-kde packages.
I see this code in /usr/share/gdebi/GDebi/GDebiKDE.py:kmathern wrote: If I recall correctly there might also be some changes you can make in the /usr/share/gdebi/GDebi/GDebiKDE.py file, we did that in the M8.5 and/or M11 gdebi-kde packages.
def installButtonClicked(self):
# if not root, start a new instance
if os.getuid() != 0:
if os.path.exists("gdebi-kde"):
executable = os.path.curdir + "/gdebi-kde"
else:
executable = "/usr/bin/gdebi-kde"
print "executable " + executable
su_cmd = "/usr/bin/kdesudo"
if not os.access(su_cmd, os.X_OK):
su_cmd = "/usr/lib/kde4/libexec/kdesu"
os.execl(su_cmd, os.path.basename(su_cmd), executable, "-n", self._deb.filename)
self.kapp.exit()
I'm thinking that kdesudo may be a dependency for gdebi, and it may have been installed along with gdebi.
Before you make any changes to the GDebiKDE.py file, can kdesudo be removed without having other packages removed? If so I would remove it.
M12 doesn't have kdesudo installed by default, and I don't recall having the authentication problems you describe with it's gdebi-kde. M12 uses the same version of gdebi & gdebi-kde as MX-14.
- uncle mark
What about just removing her user from the sudoers group?
Acer Aspire 5250 -- MX 21 KDE
Maybe. But then she wouldn't be able to `sudo this`, `sudo that`, from the command line.uncle mark wrote:What about just removing her user from the sudoers group?
As I remember, removing kdesudo was the fix for that authentication problem when it turned up in Mepis 11 (?).
Gigabyte 990FXA-UD3, AMD FX-6100 hex-core, 3.3GHz, 8G, Radeon HD6570
Right you are. I marked kdesudo for removal in Synaptic, clicked Apply, and saw there were no other packages to be removed. I tested Gdebi by re-installing a .deb file, and the application asked for a root password.DBeckett wrote:As I remember, removing kdesudo was the fix for that authentication problem when it turned up in Mepis 11 (?).
Problem solved.
Thanks to kmathern, DBeckett, and others for your sound advice.
I never understood the sudo thing, or why it's supposedly better than entering a root password or becoming root when required. I don't even bother with a user password -- KDE logs me in automatically without one. But I use a very strong root password for making changes to system files.
