First Upgrade with zero problems
Here you can post about what you did to get MX to work right with your computer or if hardware worked right out of the box for you. This is for the computers and/or hardware that is normally hard to get working right in Linux or MX.
stevedude
#1 Post by stevedude »
Just wanted to give the MX Developers some love because this is the first upgrade I had on a Linux distribution that had zero problems. I started using Linux with Ubuntu because it seemed popular at the time and had good support, but no matter if it was their 6-month upgrade or an LTS upgrade, I always had some sort of issue. Nothing ever went smoothly. I tried Deepin (Debian base) then Deepin (Manajaro base) and had issues with those. My prior system was Manjaro Gnome and again issues would occur.
I started with MX Linux 17 and the upgrade to 18 (my first with this distribution) was flawless for me. Thanks for all the planning and testing to make the roll out smooth.
OS:MX-19.2_x64|Kernel:4.15.0-1-amd64 x86_64|Xfce 4.14.2|Mobo:TUF X470-PLUS|CPU AMD Ryzen 5, 2600 MHz
PondLife
Re: First Upgrade with zero problems
#2 Post by PondLife »
+1
Off topic – why does this post disappear when I open “Active Topics”?
#3 Post by richb »
PondLife wrote: Wed Jan 02, 2019 12:45 pm +1
There is a minimum number of posts in a topic before it is listed as active. I am searching to determine what that number is.
EDIT: Found the problem. Active topics were not enabled for that sub-forum. Thanks for bringing it to my attention.
PondLife
#4 Post by PondLife »
No problem, glad it was an easy fix.
Return to “Success Stories”
