appimage experiences
Here you can post about what you did to get MX to work right with your computer or if hardware worked right out of the box for you. This is for the computers and/or hardware that is normally hard to get working right in Linux or MX.
manyroads
#1 Post by manyroads »
For those who are interested in finding another way to get access to non-standard Stretch applications (easily), I have had success (on MXLinux) using appimages. I am currently running the following apps as appimages:
- avidemux
- libreoffice-fresh
- openshot
I know this will not work in all cases, but it is often a viable and easy option. If you'd like to read more about my experience(s) you may view my posting here:
http://eirenicon.org/2018/12/18/using-linux-appimages/
Note to moderator(s): If you'd like to use my eirenicon post as a tutorial here, I'm happy to contribute it.
Re: appimage experiences
#2 Post by Jerry3904 »
Thanks. Maybe it would be good for us to collect appimage success in a thread and link it from the Wiki article.
#3 Post by Jerry3904 »
For the moment, I have added a link to your excellent post in the existing Wiki entry.
manyroads
#4 Post by manyroads »
Thank you @jerry3904!
sunrat
#5 Post by sunrat »
I'd be interested to know how much disk space these appimages take compared to native applications (if available), and why an appimage is used rather than a native application.
#6 Post by timkb4cq »
Well, I use a 95 MB appimage for Jaxx. It's because that's the only way I can get it at all for Linux.
Also appimages, if built correctly, can let you use a program version that cannot be built on the base libraries in your distro since it includes the problematic ones in the appimage and shields the program from the host's versions.
manyroads
#7 Post by manyroads »
@sunrat Here' an article I wrote on appimages. http://eirenicon.org/2018/12/18/using-linux-appimages/
Return to “Success Stories”
