E: Sub-process returned an error code
sh: 1: /usr/local/lib/desktop-menu/desktop-menu-apt-update: not found
E: Problem executing scripts DPkg::Pre-Invoke '/usr/local/lib/desktop-menu/desktop-menu-apt-update set'
For now I fix the apt problem with a temporary dismount of /usr/local to run apt. Is there now any way to resolve the conflict between what the installer put in /usr/local, and my /usr/local needs on a more practical long term basis? I can't have antiX OS software interfering with the four (on this SSD, more on others, some with more than 30) other installed distros that mount my /usr/local partition to /usr/local. I brought this up somewhere in this forum years ago. Bind mounting was suggested, but I never got that figured out or came up with any good solution.
There's another problem too: "Failed to execute login command" each time I try to login via the GUI on tty7. I have to umount /usr/local to work around that ahead of each login.
BTW, the problem leading to installing antiX in the first place is inability to get X to use the G86M [GeForce 8400M GT] chip ID: 10de:0426 with either the modesetting DDX or the nouveau DDX. It's stuck using VESA or FBDEV @1024x768 on a 1920x1080 display screen due to lack of device /dev/dri/card0 that web searches have failed to show me how to fix. This is the same on the other distros:
# xrandr --listproviders
Providers: number : 0
# xrandr
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 640 x 480, current 1024 x 768, maximum 1024 x 768
default connected 1024x768+0+0 0mm x 0mm
1024x768 0.00*
800x600 0.00
640x480 0.00
# inxi -Gxxbaz
Host: vaio Kernel: 4.9.160-antix.1-amd64-smp x86_64 bits: 64 compiler: gcc
v: 6.3.0
parameters: root=/dev/sda8 ipv6.disable=1 net.ifnames=0 noresume nomodeset
Console: N/A dm: SLiM
Distro: antiX-17.4.1_x64-full Helen Keller 28 March 2019
Type: Laptop System: Sony product: VGN-AR730E v: C3LR1E11 serial: <filter>
Chassis: type: 10 serial: N/A
Mobo: Sony model: VAIO serial: N/A BIOS: Phoenix v: R2090J8
date: 02/26/2008
Dual Core: Intel Core2 Duo T8100 type: MCP arch: Penryn speed: 1200 MHz
min/max: 1200/2101 MHz
Device-1: NVIDIA G86M [GeForce 8400M GT] vendor: Sony driver: N/A
bus ID: 01:00.0 chip ID: 10de:0426
Display: server: X.org 1.19.2 driver: nouveau,vesa
unloaded: fbdev,modesetting alternate: nv tty: 80x25
Message: Advanced graphics data unavailable in console for root.
Device-1: Marvell 88E8055 PCI-E Gigabit Ethernet vendor: Sony driver: sky2
v: 1.30 port: 3000 bus ID: 02:00.0 chip ID: 11ab:4363
Device-2: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network
driver: iwl4965 v: in-tree: port: 3000 bus ID: 06:00.0 chip ID: 8086:4229
Local Storage: total: 111.79 GiB used: 24.29 GiB (21.7%)
Processes: 140 Uptime: 24m Memory: 2.94 GiB used: 143.6 MiB (4.8%)
Init: SysVinit v: 2.88 runlevel: 5 default: 5 Compilers: gcc: 6.3.0 alt: 6
Shell: bash v: 4.4.12 inxi: 3.0.36
# hwinfo --monitor
32: None 00.0: 10000 Monitor
[Created at fb.71]
Unique ID: rdCR.EY_qmtb9YY0
Hardware Class: monitor
Model: "Generic Monitor"
Vendor: "Generic"
Device: "Monitor"
Resolution: 1024x768@76Hz
Year of Manufacture: 0
Week of Manufacture: 0
Driver Info #0:
Max. Resolution: 1024x768
Vert. Sync Range: 50-90 Hz
Hor. Sync Range: 31-61 kHz
Config Status: cfg=new, avail=yes, need=no, active=unknown
