(SOLVED)i have install geogebra but start only from terminal
dimzev
#1 Post by dimzev »
i have install geogebra but start only from terminal.
not exist geogebra icon to menu, only if you know can start programm from terminal
wan fix that ?
for me not big problem
penguin
Re: i have install geogebra but start only from terminal
#2 Post by penguin »
if it is not a problem for you, just create a new entry in MX Menu. ( Edit Applications > Add custom application).Done. If you are familiar with MenuLibre, Alcarte or Xame use them.
Return to “antiX”
