Inside to a folder i can't use shift+(start file , end file) to select multi files ...
ctrl+ works and i use this way ...but for many files is diswork...
can you help me ?
thank you !!
not work shift for sellect multi filles
- Eadwine Rose
- Administrator
Re: not work shift for sellect multi filles
For me this works, so I wonder how you are doing this?
Just keep the shift pressed the whole time, so before even clicking anything.
Eadwin Rose: believe me is not first time use shift for selecting multi files...i need this option for my works...
Please run Quick System Info then just right-click/paste in a reply. No need to copy/paste, Quick System Info already copies it for you and pre-formats it for posting in the forum. Thanks.
- Eadwine Rose
- Administrator
It is not like you click a file first, THEN press shift and select the other file.
You need to press shift first, THEN the first and last file.
It could happen that you are simply doing it in the wrong order, so I had to make sure.
Full info (inxi -zv8)
when use ctrl+file:
first press ctrl and THEN select files i want
everything works ok
when use shift+
first press shift and THEN press any file (image) on a folder
now open last editor text (it is save another folder , not the same)
i dont know why this is happening
Quick System Info i dont know where it is
thank you for your attention!!
System: Host: antix1 Kernel: 4.9.160-antix.2-486-smp i686 bits: 32 compiler: gcc v: 6.3.0
Desktop: IceWM 1.4.2 info: icewmtray dm: SLiM 1.3.4
Distro: antiX-17.4.1_386-full Helen Keller 28 March 2019
Machine: Type: Laptop System: Hewlett-Packard product: HP Compaq 6730b (GW687AV) v: F.08
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 30DD v: KBC Version 96.18 serial: <filter>
BIOS: Hewlett-Packard v: 68PDD Ver. F.08 date: 09/18/2008
Battery: ID-1: BAT0 charge: 45.3 Wh condition: 46.6/46.6 Wh (100%) volts: 12.4/11.1
model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Unknown
Memory: RAM: total: 1.90 GiB used: 1.26 GiB (66.1%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
PCI Slots: Permissions: Unable to run dmidecode. Root privileges required.
CPU: Topology: Dual Core model: Intel Core2 Duo P8400 bits: 64 type: MCP arch: Penryn
family: 6 model-id: 17 (23) stepping: 6 microcode: 60F L2 cache: 3072 KiB
bogomips: 9044
Speed: 800 MHz min/max: 800/2267 MHz Core speeds (MHz): 1: 800 2: 1600
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cx16 cx8 de
ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht lahf_lm lm mca mce mmx monitor
msr mtrr nx pae pat pbe pdcm pebs pge pni pse pse36 sep smx ss sse sse2 sse4_1 ssse3 tm
tm2 tpr_shadow tsc vme vmx vnmi xtpr
Vulnerabilities: Type: l1tf status: Vulnerable
Type: meltdown status: Vulnerable
Type: spec_store_bypass status: Vulnerable
Type: spectre_v1 mitigation: __user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline
Graphics: Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:2a42
Display: server: X.Org 1.19.2 driver: modesetting unloaded: fbdev,vesa
resolution: 1280x800~60Hz
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express x86/MMX/SSE2 v: 2.1 Mesa 13.0.6
Audio: Device-1: Intel 82801I HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:293e
Sound Server: ALSA v: k4.9.160-antix.2-486-smp
Network: Device-1: Broadcom Limited BCM4312 802.11b/g LP-PHY vendor: Hewlett-Packard driver: wl
v: kernel port: 6000 bus ID: 02:00.0 chip ID: 14e4:4315
IP v4: <filter> scope: global broadcast: <filter>
IP v6: <filter> scope: link
Device-2: Broadcom Limited NetLink BCM5787M Gigabit Ethernet PCI Express
vendor: Hewlett-Packard driver: tg3 v: 3.137 port: 6000 bus ID: 85:00.0
chip ID: 14e4:1693
WAN IP: <filter>
Drives: Local Storage: total: 111.79 GiB used: 8.32 GiB (7.4%)
ID-1: /dev/sda vendor: Toshiba model: MK1252GSX size: 111.79 GiB block size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1C scheme: MBR
Optical-1: /dev/sr0 vendor: Optiarc model: DVD-ROM DDU820S rev: MH04
dev-links: cdrom,dvd
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: none state: running
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 17.81 GiB size: 17.40 GiB (97.73%) used: 3.57 GiB (20.5%) fs: ext4
dev: /dev/sda3 label: rootantiX17.4.1 uuid: 8ae24fb5-edb9-4541-944a-d5ab12ba9855
ID-2: /home raw size: 21.30 GiB size: 20.84 GiB (97.84%) used: 1.91 GiB (9.1%) fs: ext4
dev: /dev/sda4 label: homeantiX uuid: f56b8f58-47db-454c-b046-b40a52a394d3
ID-3: /home/<filter>/pCloudDrive raw size: N/A size: 5.00 GiB used: 2.84 GiB (56.9%)
fs: fuse source: ERR-102 label: N/A uuid: N/A
ID-4: swap-1 size: 6.52 GiB used: 396 KiB (0.0%) fs: swap swappiness: 10 (default 60)
cache pressure: 50 (default 100) dev: /dev/sda5 label: N/A
uuid: 40ccc468-e3a5-4544-82b8-ee84ab6df0b5
Unmounted: ID-1: /dev/sda1 size: 1 KiB fs: <root required> label: N/A uuid: N/A
ID-2: /dev/sda2 size: 46.57 GiB fs: ext4 label: N/A
uuid: 743f0e89-2ac8-42cb-a66d-bbef565e1ecc
ID-3: /dev/sda6 size: 18.62 GiB fs: ext4 label: N/A
uuid: d478de32-5949-4f6f-b9d3-aabeaaf9bcc9
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Device-1: 3-1:2 info: Hewlett-Packard Bluetooth 2.0 Interface [Broadcom BCM2045]
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip ID: 03f0:171d
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Hub: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001
Sensors: System Temperatures: cpu: 49.0 C mobo: 40.0 C
1: deb http: //ftp.cc.uoc.gr/mirrors/linux/mx/antix/stretch stretch main nosystemd nonfree
1: deb http: //ftp.gr.debian.org/debian/ stretch-updates main contrib non-free
1: deb http: //ftp.gr.debian.org/debian/ stretch main contrib non-free
2: deb http: //security.debian.org/ stretch/updates main contrib non-free
Active apt repos in: /etc/apt/sources.list.d/geogebra.list
1: deb http: //www.geogebra.net/linux/ stable main
No active apt repos in: /etc/apt/sources.list.d/onion.list
Processes: CPU top: 5
1: cpu: 31.3% command: firefox-esr pid: 3267 mem: 432.6 MiB (22.2%)
2: cpu: 19.2% command: firefox-esr pid: 3104 mem: 429.9 MiB (22.0%)
3: cpu: 16.0% command: yad pid: 8063 mem: 22.3 MiB (1.1%)
4: cpu: 11.6% command: firefox-esr pid: 3183 mem: 319.4 MiB (16.4%)
5: cpu: 9.2% command: helium-5-amd64.hybrid.iso.torrent started by: transmission-gtk
pid: 4217 mem: 82.5 MiB (4.2%)
Memory top: 5
1: mem: 432.6 MiB (22.2%) command: firefox-esr pid: 3267 cpu: 31.3%
2: mem: 429.9 MiB (22.0%) command: firefox-esr pid: 3104 cpu: 19.2%
3: mem: 319.4 MiB (16.4%) command: firefox-esr pid: 3183 cpu: 11.6%
4: mem: 146.6 MiB (7.5%) command: firefox-esr pid: 6256 cpu: 6.6%
5: mem: 130.2 MiB (6.6%) command: pcloud pid: 5945 cpu: 0.8%
Info: Processes: 162 Uptime: 25m Init: SysVinit v: 2.88 runlevel: 5 default: 5 Compilers:
gcc: 6.3.0 alt: 6 Client: shell wrapper v: 4.4.12-release inxi: 3.0.33
everything works ok
when use shift+
First, THANK you for using code tags!
By the way, the way that I always do it is first left-click on a file or directory to select it, then press and hold shift and left-click on another file/directory lower down, and the entire range of them gets selected. (Then I release the shift key.) It's exactly the same as Windows and MacOS.
As it should.when use ctrl+file:
everything works ok
I have no idea what this means.when use shift+
Whoever requested that you run that MX tool wasn't aware that you're using antiX. It can be confusing sometimes because the MX forum tries to support both distros, MX and antiX, and the majority of topics are about MX.Quick System Info i dont know where it is
yes i know...i use it for many years...now i can'tBy the way, the way that I always do it is first left-click on a file or directory to select it, then press and hold shift and left-click on another file/directory lower down, and the entire range of them gets selected. (Then I release the shift key.) It's exactly the same as Windows and MacOS
look what i mean..I have no idea what this means.
in folder Downloads i have 3 pdf files (*.pdf)
1)when make left click on one file this, this file is open (and i see what is write inside pdf file)
2)when make shift and then left click on file , this file is open (and i see what is write inside pdf file)
3)to select one file(etc pdf) must first press ctrl and then press on file (to make grey),then (with holding press ctrl ) i can choose many filles
but
when press shift to press another file to select all files then open text editor like image below
https://i.ibb.co/FJY1v3V/screenshot.jpg
i dont understand why happen this...
thank for your attention!!!
mod note: image changed to link, please be mindful of the size of remote linked images
viewtopic.php?f=133&t=48374
Your file manager may be set up such that a single-click opens files rather than just selecting them (a single-click opens files instead of a double-click.) In fact, I'm very sure that's what is happening. I know how to change settings in MX to fix that but I don't remember how to do it in antiX, but I'm sure someone can tell you. If you're using SpaceFM there must be something in its settings that you can change to eliminate that behavior. You can explore its dropdown menus and settings and see if you can find it yourself.
Usually if single-click is configured to open files then hover the mouse cursor over the file without clicking will select. Does hovering the cursor light up the selection rectangle?
Also it appears you have .pdf files configured to open in Geany text editor which is wrong. Do you have a PDF viewer on your system such as qpdfview? You should change your settings to make that the default application.
I think you have two separate problems both of which should be easy to fix.
