I have a Acer X233H monitor, would like to know what CLI command to visualize the age of the connected monitor/manufactured date and specifications.
I am running: Distro: antiX-19.b1_x64-full Marielle Franco 12 June 2019
Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <root required>
UEFI [Legacy]: American Megatrends v: P1.10 date: 06/19/2018
Topology: Quad Core model: AMD Ryzen 3 2200G with Radeon Vega Graphics
bits: 64 type: MCP L2 cache: 2048 KiB
Speed: 1600 MHz min/max: 1600/3500 MHz Core speeds (MHz): 1: 1600 2: 1600
3: 1600 4: 1600
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
driver: N/A
Display: x11 server: X.Org 1.20.4 driver: vesa resolution: 1920x1080~N/A
OpenGL: renderer: llvmpipe (LLVM 7.0 128 bits) v: 3.3 Mesa 18.3.6
JR
Command to discover info about my Monitor
Re: Command to discover info about my Monitor
Maybe
inxi -Gvv
inxi -Gvv
Try
hwinfo --monitor
Earl
hwinfo --monitor
Earl
The following command gives you resolution info':
If you are running more than one display, then it will add their vertical dimensions together.
xdpyinfo | grep -B2 resolution
$ inxi -Gvv
CPU: Quad Core AMD Ryzen 3 2200G with Radeon Vega Graphics (-MCP-) speed/min/max: 1600/1600/3500 MHz
Kernel: 4.9.176-antix.1-amd64-smp x86_64 Up: 12d 21h 01m Mem: 1233.3/6972.6 MiB (17.7%) Storage: 447.13 GiB (1.6% used)
Procs: 176 Shell: bash 5.0.3 inxi: 3.0.33
green600@antix2:~
$ hwinfo --monitor
40: None 00.0: 10000 Monitor
[Created at fb.71]
Unique ID: rdCR.EY_qmtb9YY0
Hardware Class: monitor
Model: "Generic Monitor"
Vendor: "Generic"
Device: "Monitor"
Resolution: 1024x768@76Hz <------------------- am using this monitor @ 1920x1080
Year of Manufacture: 0 <------------------- Would think this monitor was manufactured in 2009
Week of Manufacture: 0
Driver Info #0:
Max. Resolution: 1024x768
Vert. Sync Range: 50-90 Hz
Hor. Sync Range: 31-61 kHz
Config Status: cfg=new, avail=yes, need=no, active=unknown
green600@antix2:~
$ xdpyinfo | grep -B2 resolution
screen #0:
dimensions: 1920x1080 pixels (513x292 millimeters)
resolution: 95x94 dots per inch
green600@antix2:~
Moving a lot of furniture about to see the label on the back side of the Monitor (Manufactured: March 10th 2009)
My guess was decently close. Side by side with other old monitor Manufactured: February 2013 the screen on this one is brownish and colors are not very saturated. 10 years for $150 I guess was decent service.
JR
green600@antix2:~
$ hwinfo --monitor
[Created at fb.71]
Vendor: "Generic"
Device: "Monitor"
Driver Info #0:
green600@antix2:~
screen #0:
green600@antix2:~
JR
Yet another way:
xrandr --prop
