I have used the Menu Editor a couple of times, but it no longer appears in Control Center, and I cant find it anywhere else: how can I get it back?
And now screenshot is borked: guess I must reinstall!
[SOLVED Twice]Lost Menu Editor.
Re: Lost Menu Editor.
You can go to MX Tweak in MX Tools and try to restore the stuff you think is borked.
You can also use MXPI to install mx-apps (meta package). That may reinstall what you 'fixed'.
Pretty similar... try to find the equivalent function(s) in the "Control Center" or in cli-aptiX.
No joy: I will try reinstalling. See you later!
I'm back and posting from AntiX. All better now.
Now for updates: hope they don't wreck it!
Thanks for trying to help.
Re: [SOLVED]Lost Menu Editor.
Now in fully-updated antiX 17.4.1 with Menu Editor working OK.
My problems now:-
Applications are very slow to start.
Cannot install my (network) printer and browser cannot see the CUPS server.
Advice welcome.
My problems now:-
Advice welcome.
- Eadwine Rose
- Administrator
You might want to start a new topic on that since the menu editor issue has been solved.
Will do that if no help comes here.Eadwine Rose wrote: ↑Mon May 20, 2019 6:37 am You might want to start a new topic on that since the menu editor issue has been solved.
