[SOLVED] Change DNS server
How can I change the DNS servers on antiX 17?
Re: Change DNS server
/etc/dhcp/dhclient.conf
Thanks for your reply, and sorry for my late reply.
I opened that file, but in the red text with settings did not see a server I recognised as the current server (i.e. ISP's).
I assume I have no add 1 or 2 new lines to override whatever it currently uses. Can you tell me what to add and where?
I don't know about antiX but on MX it's 'Network Connections' Program under the IPv4 settings tab there is a place for DNS servers. You maybe able to bring it up by right clicking you network icon and Edit Connections. At least it something to look for.
Thanks for jumping in, Towwire.
Yes, I tried that because my other computer runs on Mint, and that's how Mint has it configured too; Mint advises againt editing the .conf file, so I was nervous about anticapitalista's recommendation, although I did look at the file and there was no warning.
Anyway, antiX has a slightly different configuration from Mint. You triggered me to look again. On antiX I am using Wicd and if you click on the properties button of your network the relevant boxes are displayed.
