[SOLVED] touch screen
Klaas Vaak
#1 Post by Klaas Vaak »
1 of my laptops is a Lenovo Yoga with a touch screen. Is there a software setting to turn it off?
Paul..
Re: touch screen
#2 Post by Paul.. »
Wild Guess: Try Settings->Mouse & Touchpad->see the Devices pull down menu...is the touchscreen listed? If yes, configure?
Samsung 860 500GB SSDs (2)
caprea
Re: touch screen
#3 Post by caprea »
Talking still antiX, yes ?
You can have a look at this, I didn't try it, though ( no touchscreen here )
https://www.youtube.com/watch?v=MdmnIG5ZVM4
Afaik, xinput isn't installed by default on antiX
sudo apt-get install xinput
You can also look at
man xinput
Paul..
Re: touch screen
#4 Post by Paul.. »
Ouch! Sorry, caprea...my goof...yes my answer was in MX-speak
Klaas Vaak
Re: touch screen
#5 Post by Klaas Vaak »
@Caprea: yes, still talking antiX
I did not bother with xinput because, according to the Youtube video, it is a temporary, session-only measure. The video also shows a permanent measure, which is what I implemented.
Thanks for your help.
caprea
Re: [SOLVED] touch screen
#6 Post by caprea »
Well done!
Klaas Vaak
#7 Post by Klaas Vaak »
caprea wrote: Wed Mar 13, 2019 10:53 amWell done!
Well done to you too, without your help I could not have achieved it :celebrate:
Return to “antiX”
