inxi/pinxi testers! big weather update
I'm about to do a new inxi, the current api that inxi uses for weather data is apparently about to vanish, so I've implemented a much more robust permanent solution, by moving the primary api to smxi.org, where I can use various apis, some requiring keys, to generate output for inxi/pinxi.
Just to make sure nothing weird happens, can you test current latest pinxi (3.0.30-9) and confirm all weather functionality is working as expected.
Note that for -W custom locations, the api's do not work as reliably as the old one, but there's also now an option where you can trigger using alternate apis:
Sample: pinxi -xxxW --weather-source 1
Weather source takes 4 options, 0 to 3, 0 will use the old logic inside of inxi, but that's probably going to be going offline quite soon.
There's also some new data, snow/rain/cloud cover to make the change better.
With this new logic, I will be able to update api's to all inxi's via the smxi.org tool because I can simply change which api is used for default.
There's also enhanced error handling, which gives somewhat ok messages, though I need to translate some of them into english.
The Debian freeze for next stable is a few days away so I need to get this into inxi master as quickly as possible, today by the latest, freeze is feb 12 I believe.
thanks for looking and testing.
Post the full output of either -wxxx or -Wxxx and if you use --weather-source (short --ws) let me know that.
Re: inxi/pinxi testers! big weather update
Seems to work fine here (except "annoying" is missing ;-D)
$ pinxi -wxxx
Weather: Temperature: 4 C (39 F) Conditions: Light rain Wind: from SSW at 2.7 m/s (10 km/h, 6 mph)
Cloud Cover: 100% Rain: 3 mm (0.12 in) Humidity: 96% Pressure: 991.1 mb (29.73 in)
Dew Point: 4 C (39 F) Location: Seneca Falls, NY, USA
Current Time: Wed 06 Feb 2019 06:19:20 PM EST (America/New_York)
Observation Time: Wed 06 Feb 2019 05:56:00 PM EST
- rokytnji.1
- Global Moderator
Motorcycle shop Desktop computer
harry@shop1:~
$ pinxi -Fxx
System: Host: shop1 Kernel: 4.9.0-0.bpo.5-amd64 x86_64 bits: 64 compiler: gcc v: 4.9.2
Desktop: Xfce 4.12.2 tk: Gtk 2.24.25 wm: xfwm4 dm: LightDM
Distro: MX-16_x64 Metamorphosis 12 December 2016 base: Debian GNU/Linux 8 (jessie)
Machine: Type: Desktop System: Dell product: Precision WorkStation T3400 v: N/A
serial: <root required> Chassis: type: 7 serial: <root required>
Mobo: Dell model: 0TP412 serial: <root required> BIOS: Dell v: A09 date: 06/04/2009
CPU: Topology: Dual Core model: Intel Core2 Duo E7400 bits: 64 type: MCP arch: Penryn
rev: A L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 ssse3 bogomips: 11163
Speed: 2791 MHz min/max: N/A Core speeds (MHz): 1: 2791 2: 2791
Graphics: Device-1: NVIDIA G71 [GeForce 7900 GS] driver: nouveau v: kernel bus ID: 01:00.0
chip ID: 10de:0292
Display: server: X.Org 1.16.4 driver: nouveau unloaded: fbdev,modesetting,vesa
alternate: nv resolution: 1920x1080~60Hz
OpenGL: renderer: Gallium 0.4 on NV49 v: 2.1 Mesa 12.0.3 direct render: Yes
Audio: Device-1: Intel 82801I HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:293e
Sound Server: ALSA v: k4.9.0-0.bpo.5-amd64
Network: Device-1: Broadcom NetXtreme BCM5754 Gigabit Ethernet PCI Express
vendor: Dell Precision T3400 driver: tg3 v: 3.137 port: dc80 bus ID: 04:00.0
chip ID: 14e4:167a
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 00:24:e8:41:75:98
Drives: Local Storage: total: 149.05 GiB used: 50.59 GiB (33.9%)
ID-1: /dev/sda vendor: Seagate model: ST3160812AS size: 149.05 GiB speed: 3.0 Gb/s
serial: 5LSEMKYE temp: 40 C
Partition: ID-1: / size: 7.56 GiB used: 4.94 GiB (65.2%) fs: ext4 dev: /dev/sda5
ID-2: /home size: 15.06 GiB used: 2.36 GiB (15.7%) fs: ext4 dev: /dev/sda6
ID-3: swap-1 size: 3.91 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda8
Sensors: System Temperatures: cpu: 34.0 C mobo: N/A gpu: nouveau temp: 62 C
Fan Speeds (RPM): cpu: 1071 mobo: 1283
Info: Processes: 184 Uptime: 1h 54m Memory: 3.80 GiB used: 1.18 GiB (31.2%) Init: SysVinit
v: 2.88 runlevel: 5 default: 5 Compilers: gcc: 4.9.2 alt: 4.9 Shell: bash v: 4.3.30
running in: xfce4-terminal pinxi: 3.0.30-9
harry@shop1:~
$ pinxi -xxxW pecos,texas
Weather: Temperature: 23 C (73 F) Conditions: Few clouds
Wind: from WNW at 6.6 m/s (24 km/h, 15 mph) Cloud Cover: 17% Humidity: 37%
Pressure: 914.825 mb (27.44 in) Dew Point: 7 C (45 F) Location: Pecos, Texas
Current Time: Wed 06 Feb 2019 05:24:37 PM CST
Observation Time: 2019-02-06 17:24:37 (America/Chicago -0600)
Looking good from Australia:
$ pinxi -wxxx
Weather:
Temperature: 26 C (79 F) Conditions: Broken clouds
Wind: from NNW at 0.9 m/s (3 km/h, 2 mph) Cloud Cover: 75% Humidity: 74%
Pressure: 1006.3 mb (30.19 in) Dew Point: 21 C (70 F)
Current Time: Thu 07 Feb 2019 10:30:31 AEDT (Australia/Victoria)
Observation Time: Thu 07 Feb 2019 10:00:00 AEDT
Hmm, maybe I should move dew point to right after humidity, that would make more sense.
Anyone in russia or other country without a euro style character set?
All looks good so far, thanks.
pinxi -wxxx
Weather: Temperature: 1 C (34 F) Conditions: Freezing rain
Wind: from N at 4.6 m/s (17 km/h, 10 mph) Cloud Cover: 100% Rain: 3 mm (0.12 in)
Humidity: 95% Pressure: 1000.6 mb (30.02 in) Dew Point: -0 C (32 F)
Current Time: Wed 06 Feb 2019 06:40:44 PM EST (America/New_York)
Observation Time: Wed 06 Feb 2019 06:21:00 PM EST
Hi H2-1,
The --weather-source 3 ... seems the best here.
$ ./pinxi -xxxW Paris,FR --weather-source 0 # old
Weather: Temperature: 10 C (50 F) Conditions: Overcast Wind: from South at 5.4 m/s (19 km/h, 12 mph) Humidity: 94%
Pressure: 1015 mb (29.98 in) Dew Point: 9 C (48 F) Location: Paris, FR altitude: 86 m (282 ft)
Current Time: 2019-02-07 00:50:23 Observation Time: February 7, 12:30 AM CET
$ ./pinxi -xxxW Paris,FR --weather-source 1
Current Time: 2019-02-07 00:50:24 Observation Time: February 7, 12:30 AM CET
$ ./pinxi -xxxW Paris,FR --weather-source 2
Weather: Temperature: 9 C (48 F) Conditions: light intensity drizzle Wind: from S at 5.1 m/s (18 km/h, 11 mph)
Cloud Cover: 90% Humidity: 93% Pressure: 1015 mb (30.45 in) Location: Paris, FR
Current Time: 2019-02-07 00:50:26 Observation Time: N/A
$ ./pinxi -xxxW Paris,FR --weather-source 3
Weather: Temperature: 9 C (48 F) Conditions: Drizzle Wind: from SSW at 2.7 m/s (10 km/h, 6 mph) Cloud Cover: 100%
Rain: 0.172 mm (0.01 in) Humidity: 97% Pressure: 1007 mb (30.21 in) Dew Point: 9 C (48 F)
Observation Time: 2019-02-06 23:50:00 (Europe/Paris +0100)
Great, thanks for testing --weather-source too.
I had to hurry this process so all the testing is appreciated, so far I have only seen a few small missing things and have corrected those subtle points.
Note that I can add api's transparently to inxi users in the future, which means, if one goes away, I can change the default in the api logic and the only difference inxi users would see would be some fields missing data, and the ability to detect locations well changing, along with changes in -W ability to detect the locations, that varies quite a bit between apis I have found.
I built in the possibility to use up to 9 apis with --weather-source, which also has a corresponding user configuration item:
WEATHER_SOURCE=[0-9]
this lets users pick the one they want if the default is not giving the results as expected.
I found also during testing that the varous apis have quite different weather, lol, some clearly had to be wrong, so I built in an option to let you switch sources if you want via config option.
Note that if you use an unsupported value, you'll just get an error on the weather request telling you that, which lets you know the smxi api logic does not yet support, say, api 4.
I may add 4 over the coming days, but that won't impact inxi itself.
Well done. The automatic location data is correct unlike some other weather sites which auto-locate me in one or another of the nearby cities. Looks from the formatting like it defaults to weather-source 3 for my location.
tim@mx15:~
$ pinxi -xxxw --weather-source 0
Weather: Temperature: 21 C (70 F) Conditions: Clear Wind: from WNW at 4.0 m/s (14 km/h, 9 mph) Humidity: 73%
Dew Point: 16 C (61 F) Pressure: 1020 mb (30.13 in) Location: Pinellas Park, FL, USA altitude: 5 m (16 ft)
Current Time: Wed 06 Feb 2019 06:56:15 PM EST (America/New_York) Observation Time: Wed 06 Feb 2019 05:53:00 PM EST
tim@mx15:~
$ pinxi -xxxw --weather-source 1
Current Time: Wed 06 Feb 2019 06:56:17 PM EST (America/New_York) Observation Time: Wed 06 Feb 2019 05:53:00 PM EST
tim@mx15:~
$ pinxi -xxxw --weather-source 2
Weather: Temperature: 22 C (72 F) Conditions: broken clouds Wind: from NW at 2.6 m/s (9 km/h, 6 mph) Cloud Cover: 75%
Humidity: 73% Pressure: 1021 mb (30.63 in) Location: Pinellas Park, FL, USA
Current Time: Wed 06 Feb 2019 06:56:20 PM EST (America/New_York) Observation Time: Wed 06 Feb 2019 06:35:00 PM EST
tim@mx15:~
$ pinxi -xxxw --weather-source 3
Weather: Temperature: 21 C (70 F) Conditions: Clear sky Wind: from WNW at 1.3 m/s (5 km/h, 3 mph) Cloud Cover: 25%
Humidity: 80% Dew Point: 18 C (64 F) Pressure: 1019.9 mb (30.6 in) Location: Pinellas Park, FL, USA
Current Time: Wed 06 Feb 2019 06:56:22 PM EST (America/New_York) Observation Time: Wed 06 Feb 2019 06:39:00 PM EST
tim@mx15:~
$ pinxi -xxxw
Current Time: Wed 06 Feb 2019 06:56:43 PM EST (America/New_York) Observation Time: Wed 06 Feb 2019 06:39:00 PM EST
oops, that's good to know, because 3 is currently the default on smxi.org. pinxi by default requests the remote default, which can be changed if I need to do that.
2 is buggy, and does not support, or at least did not in testing, spaces in city/country names (spaces via '+' sign). It also tends to miss many city,state values.
4 may be added.
4 may be added.
