Hi!
Last time I installed antiX on an old 32-bit machine I saw an option to add a minimal Xfce desktop. I didn't do it at the time, but I've thought about having a totally systemd-free version of MX if there could be such a thing... having no systemd at all anywhere, not even as a dependency. Could that be done using the "add minimal Xfce" option to antiX and would I still have all the cool MX tools?
I did search around the Wiki and I did look around for community respins, and I'm sure I'm not the first or only one hoping to achieve such a thing. Can it be done?
"Minimal Xfce" option
Re: "Minimal Xfce" option
There's currently no antiX click-a-button "add minimal Xfce" option. Maybe you had seen that in an experimental (antiX14 b3) release?
antiX repositories won't have the MX Tools, so you would need to sort out: which repo(s) can be used successfully in tandem.
Probably all of the Qt5 components utilized by the various MX Tools are available to (but not pre-installed in) antiX.
If you decide to be a trailblazer by experimenting with this mix-n-match, keep copious notes so that others may follow, eh.
ps:
Ahead of time, you should get familiar with the documentation for apt pinning (apt mark) and advanced apt preferences configuration.
You'll probably need to mark "always prefer version from (mxrepo)" for the MX Tools pkgs and their Qt5 et al dependent pkgs.
ps:
actually a large number of the "mx-tools" have antiX counterparts already, they just don't have the MX name attached.skidoo wrote: ↑Sun Feb 03, 2019 2:02 pm There's currently no antiX click-a-button "add minimal Xfce" option. Maybe you had seen that in an experimental (antiX14 b3) release?
ps:
iso-snapshot
live-usb-maker-gui-antiX
Package Installer (only the popular apps tab, which has minimal Xfce under Desktop Environments)
ddm-mx (nvidia-installer)
boot-repair
codecs-installer
repo-manager
are pre-installed on the antiX 17.3.1 "full" iso.
and the updater (apt-notifier) and idevice-mounter are available in Package Installer->Utilities.
even the installers are the same, although with a different distro-specific data package attached for themeing and a few distro-specific behind-the-scenes type pieces.
So you could get very close just putting Xfce on top of antiX now (which is what I used to do before MX).
It wasn't during installation but afterwards during setup... I'm not very technologically minded, so perhaps I am reaching too far for me.
- rokytnji.1
- Global Moderator
Made me look.There's currently no antiX click-a-button "add minimal Xfce" option. Maybe you had seen that in an experimental (antiX14 b3) release?
If I was to approach this thread topic with my style.
I would grab a large usb drive.
Run my clueless experiment on a live persistent install.
If it breaks. No harm no foul. Reinstall experience is good experience also.
Thanks @rokytnji.1 very much! I'll go for it. What I'm hoping to accomplish is an Xfce OS that is completely totally absolutely and certifiably systemd-free distro without even the suggestion of systemd even as a dependency. But not Devuan, not Slackware. Just for grins and giggles. The funny thing is, I don't even care that much about systemd, I can take it or leave it, personally. But I have some paranoid friends on Diaspora that love Debian but refuse to use it now because of systemd.
And besides, it can't hurt for technophobic Baku boy to explore a little more deeply.
what makes this option in antiX?
apt-get install xfce4?
To open the packageinstaller in antiX (as seen in roky's screenshot):
sudo packageinstaller
From Baku or in Baku? We just added a mirror in Baku...And besides, it can't hurt for technophobic Baku boy to explore a little more deeply.
