I have downloaded and installed salome_meca under antiX live persistent mode on an external SSD, but when I start salome an error occurs:
runSalome running on antix1
Searching for a free port for naming service: 2810 - OK
Searching Naming Service found in 0.0 seconds
Searching /Kernel/Session in Naming Service ++libGL error: unable to load driver: i965_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: i965
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
+Warning: this type (SALOME_MED/MEDCouplingFieldDoubleCorbaInterface,objref) already exists, it will be ignored.
How can I try to fix it ?
Regards,
marcoC
antiX ++libGL error: unable to load driver: i965_dri.so
Re: antiX ++libGL error: unable to load driver: i965_dri.so
Try installing the i965 drivers. They should be in the repo.
Solved.
It is necessary to rename libstdc++.so.6 in ~/Live-usb-storage/V2018.0.1_public/prerequisites/debianForSalome/lib as follows:
mv libstdc++.so.6 libstdc++.so.6_
The i965 libraries should be installed by default in antiX.
It's also better practice to create a symlink to a library with the new name instead of renaming it, even though that's a library that shipped with the program and not a system one.
