Has anybody had any luck getting thinkfan to work with Thinkpads I have a T430 an having trouble getting control of the fan..Most of the set ups a for systemd
tpfancontrol works fine with windows..
Thanks and Happy Xmas
Thinkfan T430 not working
Main : MX 19.1-AHS (i3) 5.4.13-1~mx19+1, Asus B450-i AMD 5 3600 , 32gb Hyper-X 3200 , GTX970 .
- rokytnji.1
- Global Moderator
Re: Thinkfan T430 not working
I have no need to control fan speeds on the fly. Have you installed lm sensors yet
https://packages.debian.org/stretch/lm-sensors
harry@biker:~
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Physical id 0: +42.0°C (high = +87.0°C, crit = +105.0°C)
Core 0: +42.0°C (high = +87.0°C, crit = +105.0°C)
Core 1: +41.0°C (high = +87.0°C, crit = +105.0°C)
acpitz-virtual-0
Adapter: Virtual device
temp1: +41.0°C (crit = +104.0°C)
thinkpad-isa-0000
fan1: 3242 RPM
harry@biker:~
$ inxi -M
Machine: Type: Laptop System: LENOVO product: 2347DS2 v: ThinkPad T430 serial: <root required>
Mobo: LENOVO model: 2347DS2 serial: <root required> UEFI [Legacy]: LENOVO
v: G1ET41WW (1.16 ) date: 05/25/2012
harry@biker:~
$ inxi -S
System: Host: biker Kernel: 4.9.83-antix.1-686-smp-pae i686 bits: 32 Desktop: IceWM 1.3.8
Distro: antiX-15-V_386-full Killah P 30 June 2015
harry@biker:~
And yet systemd is so simple...
It doesn't work because in the newer models the file
/proc/acpi/ibm/thermal
is no longer available. The temperature sensors are at a different location in the Sysfs.
Install the package lm-sensors as written by roky.
@ rokytnji.1 & male Thanks for trying to help with this, but fast getting over it..like the fan
This is after running sensors-detect and editing the thinkfan.conf file. and a cpu temp of 40c and hdd temp 39c
The fan runs at about 2400 rpm on startup if I open web browser it go 3500 rpm
This my /etc/thinkfan.conf
This after setting up and reboot..
This very annoying
koo@antix17:~➤ inxi -M
Type: Laptop System: LENOVO product: 2349GCM v: ThinkPad T430
Mobo: LENOVO model: 2349GCM serial: <root required> UEFI: LENOVO
v: G1ETB8WW (2.78 ) date: 09/19/2018
▶▶▶ 11:38:40 AM Thu Dec 27 2018 ◀◀◀
koo@antix17:~➤ inxi -S
Host: antix17 Kernel: 4.19.10-antix.1-amd64-smp x86_64 bits: 64 Desktop: i3 4.16
Distro: antiX-17.2_x64-full Helen Keller 4 October 2018
# I use this on my T61p:
#tp_fan /proc/acpi/ibm/fan
#tp_thermal /proc/acpi/ibm/thermal (0, 10, 15, 2, 10, 5, 0, 3, 0, 3)
hwmon /sys/devices/platform/coretemp.0/hwmon/hwmon2/temp3_input
hwmon /sys/devices/platform/coretemp.0/hwmon/hwmon2/temp1_input
hwmon /sys/devices/platform/coretemp.0/hwmon/hwmon2/temp2_input
hwmon /sys/devices/virtual/thermal/thermal_zone0/hwmon0/temp1_input
(0, 0, 55)
(1, 48, 60)
(2, 50, 61)
(3, 52, 63)
(4, 56, 65)
(5, 59, 66)
(7, 63, 32767)
koo@antix17:~➤ sensors
coretemp-isa-0000
Package id 0: +50.0°C (high = +87.0°C, crit = +105.0°C)
Core 0: +41.0°C (high = +87.0°C, crit = +105.0°C)
Core 1: +50.0°C (high = +87.0°C, crit = +105.0°C)
thinkpad-isa-0000
fan1: 3781 RPM
You can't just apply the T61p's shift thresholds to your T430.KoO wrote:Code: Select all
# I use this on my T61p: .... (0, 0, 55) (1, 48, 60) (2, 50, 61) (3, 52, 63) (4, 56, 65) (5, 59, 66) (7, 63, 32767)
Look for examples on the net or in /usr/share/doc/thinkfan/example/ and the README.Debian
https://man.cx/thinkfan(1)
