Removing ecryptfs-utils on antiX ???
caprea
#1 Post by caprea »
Now this is pretty strange.
On antix 17.2 stable repos
after doing an update and afterwards an dist-upgrade , apt wants to remove ecryptfs-utils
helga@antix1:~
$ LANG=C sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  ecryptfs-utils libecryptfs1 libtspi1
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
The last thing that was updated was nvidia-legacy-340xx-driver
to 340.107-2 mx17+1
$ inxi -r
  1: deb https://mxlinux.mirror.iphh.net/packages/antix/stretch/ stretch main nosystemd nonfree
  1: deb http://mirror.eu.oneandone.net/debian/ stretch-updates main contrib non-free
  1: deb http://mirror.eu.oneandone.net/debian/ stretch main contrib non-free
  No active apt repos in: /etc/apt/sources.list.d/mx.list
  No active apt repos in: /etc/apt/sources.list.d/onion.list
  1: deb https://deb.opera.com/opera-stable/ stable non-free
  1: deb http://repo.vivaldi.com/stable/deb/ stable main
helga@antix1:~
/var/log/apt/history.log
Commandline: apt-get dist-upgrade
Requested-By: helga (1000)
Install: repo-list:amd64 (0.1.0, automatic)
Upgrade: nvidia-legacy-340xx-driver-bin:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), antix-viewer:amd64 (0.1.1, 0.1.2), xserver-xorg-video-nvidia-legacy-340xx:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libegl1-nvidia-legacy-340xx:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libegl1-nvidia-legacy-340xx:i386 (340.106-2~deb9u1, 340.107-2~mx17+1), nvidia-legacy-340xx-vdpau-driver:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), installer-data-antix:amd64 (0.1.5, 0.1.6), libgles1-nvidia-legacy-340xx:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libgles1-nvidia-legacy-340xx:i386 (340.106-2~deb9u1, 340.107-2~mx17+1), nvidia-legacy-340xx-kernel-dkms:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), nvidia-detect:amd64 (384.130-1, 390.87-2~bpo9+1~mx17+2), libnvidia-legacy-340xx-eglcore:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libnvidia-legacy-340xx-eglcore:i386 (340.106-2~deb9u1, 340.107-2~mx17+1), nvidia-legacy-340xx-driver-libs:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), nvidia-legacy-340xx-driver-libs:i386 (340.106-2~deb9u1, 340.107-2~mx17+1), nvidia-legacy-340xx-driver-libs-i386:i386 (340.106-2~deb9u1, 340.107-2~mx17+1), antix-installer:amd64 (1.0.4.4, 1.0.4.5), libgl1-nvidia-legacy-340xx-glx:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libgl1-nvidia-legacy-340xx-glx:i386 (340.106-2~deb9u1, 340.107-2~mx17+1), qt5ct:amd64 (0.33-1~bpo9+1, 0.33-1mx17+1), youtube-dl:amd64 (2018.11.07-1, 2018.12.09-0.1~mx17+1), libgles2-nvidia-legacy-340xx:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libgles2-nvidia-legacy-340xx:i386 (340.106-2~deb9u1, 340.107-2~mx17+1), tlp:amd64 (0.9-3, 1.1-1~mx17+1), smtube:amd64 (18.9.0+2.1, 18.11.0-0.1~mx17+1), spacefm-common:amd64 (1.0.6-1.1, 1.0.6-3~mx17+1), spacefm:amd64 (1.0.6-1.1, 1.0.6-3~mx17+1), nvidia-legacy-340xx-kernel-support:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libnvidia-legacy-340xx-glcore:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libnvidia-legacy-340xx-glcore:i386 (340.106-2~deb9u1, 340.107-2~mx17+1), broadcom-sta-dkms:amd64 (6.30.223.271-7mx17+2, 6.30.223.271-9.1~mx17+1), nvidia-legacy-340xx-driver:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), ddm-mx:amd64 (18.10.01, 18.11.01), libnvidia-legacy-340xx-ml1:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), repo-manager:amd64 (0.1.12, 0.1.13), nvidia-legacy-340xx-alternative:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libnvidia-legacy-340xx-cfg1:amd64 (340.106-2~deb9u1, 340.107-2~mx17+1), libnvidia-legacy-340xx-cfg1:i386 (340.106-2~deb9u1, 340.107-2~mx17+1)
End-Date: 2018-12-16  09:03:38
Re: Removing ecryptfs-utils on antiX ???
#2 Post by Stevo »
Might be that the new installer doesn't need those, but you can mark those as manually installed to prevent the autoremove.
caprea
#3 Post by caprea »
Maybe, I was disconcerted because removing it caused some trouble during the mx-updates
if you have have the home only encryption
https://forum.mxlinux.org/viewtopic.php ... 50#p472550
Richard
#4 Post by Richard »
Haven't used data encryption lately,
but I remember I was told to forget about updating
if you want to maintain access to your encrypted data.
This may just be an old history tale,
but it would worry me if my data were encrypted.
caprea
#5 Post by caprea »
Yes, the new installer doesn't depend on ecryptfs-utils anymore.
Is it now save to autoremove it on antiX ?
#6 Post by dolphin_oracle »
caprea wrote: Sun Dec 16, 2018 10:49 pm Yes, the new installer doesn't depend on ecryptfs-utils anymore.
probably safe on antiX, unless you have used an encyrpted home. You would have to do that manually on antiX though, because the antix version of the installer didn't offer encrypted home.
#7 Post by anticapitalista »
dolphin_oracle wrote: Sun Dec 16, 2018 11:13 pm
Exactly.
Return to “antiX”
