Static Persistence Live USB
I am running a live USB with antiX 17 on it, I use static persistence with retains updates, software installed and documents saved in the Home folder. The problem I have is when I update the repos as I did recently as seen below due to issues with the non free repo, the changes in /etc/apt/sources.list.d/antix.list are not retained after a reboot or shutdown. Can anyone help me with making these repo changes permanent I used sudo nano /etc/apt/sources.list.d/antix.list and used ^O - Write Out in nano to save and ^X - Exit to exit changes. The changes are retained in session but as soon as you reboot they are overwritten with the original repo file.
Using static persistence I thought would retain the editing of /etc/apt/sources.list.d/antix.list but it appears otherwise, could anyone advise me on the way to retain changes in /etc/apt/sources.list.d/antix.list on a live usb with persistence.
To get rid of repo error
As a result of a request from one of our users, we have moved non free packages out of the antiX main folder to its own nonfree one. The new nonfree section applies to antiX stretch, testing and sid repos.
As you can see in the stretch nonfree repo antiX stretch/nonfree debs this includes a few packages, but for testing and sid only adobe-flashplugin.
Users should change their /etc/apt/sources.list.d/antix.list if you want to upgrade non-free debs to this:
# Use with Debian Stable/stretch repositories. Set as default for antiX-17. Note new repos
deb http://repo.antixlinux.com/stretch stretch main nosystemd nonfree
# Use with Debian Testing repositories.
#deb http://repo.antixlinux.com/testing testing main nosystemd nonfree
# Use with Debian Sid repositories.
#deb http://repo.antixlinux.com/stretch stretch main nosystemd nonfree
Of course, if you want to be clean/libre than do not use nonfree nor non-free in debian.list in the repo lists.
Re: Static Persistence Live USB
If you remaster does it preserve that change?
I will try a remaster still learning the process of remastering but will give it a go thanks for the tip.
I cannot duplicate the OP's experience. for me, with static persistence, any change to the .list files is maintained across reboots.
I think there are 2 possibilities. 1. the changes didn't actually save to the .list files, or 2. that some other persistence mode, perhaps /home persistence only, was used and such changes to the root filesystem were only live.
I tried a remaster but still changes to /etc/apt/sources.list.d/antix.list are not retained after reboot, the changes must be saved because when I exit /etc/apt/sources.list.d/antix.list and apt-get update the new repos function correctly. It is only after reboot or shutdown the changes are lost. With reference to dolphin_oracle - '2. that some other persistence mode, perhaps /home persistence only, was used and such changes to the root filesystem were only live' I tried to check on my persistence state, as far as i can tell I'm using static_persistence with persist root enabled so those file system changes should be retained. Still have same problem in repo update not being retained on a live usb with persistence. Check out a screencast of my live system issue here https://youtu.be/FXP-7ANg5ts
To change antiX repos do use Control Center from the menu: -> Control Center -> Maintenance -> Manage APT Repos
After changing repos do show the output of this command line:
(copy & paste into the terminal command line )
inxi -Fxrz; cat /proc/cmdline ; head /etc/live/persist-config.conf /etc/apt/sources.list.d/antix.list ;
Note: Do wrap the text-output between code-tags [code] here [/code] for better readability by pressing the code-tag icon </> above the editor window or type manually [code] ... [/code]
Here is the output:
demo@antix1:~
$ inxi -Fxrz; cat /proc/cmdline ; head /etc/live/persist-config.conf /etc/apt/sources.list.d/antix.list ;
Host: antix1 Kernel: 4.9.87-antix.1-amd64-smp x86_64 bits: 64 compiler: gcc v: 6.3.0
Desktop: IceWM 1.4.2 Distro: antiX-17.1_x64-full Heather Heyer 17 March 2018
Type: Laptop System: HP product: HP EliteBook 850 G3 v: N/A serial: <filter>
Mobo: HP model: 8079 v: KBC Version 85.77 serial: <filter> UEFI: HP
v: N75 Ver. 01.24 date: 01/30/2018
ID-1: BAT0 charge: 42.8 Wh condition: 44.4/44.4 Wh (100%)
model: Hewlett-Packard Primary status: Unknown
Topology: Dual Core model: Intel Core i5-6300U bits: 64 type: MT MCP arch: Skylake
rev: 3 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19972
Speed: 2793 MHz min/max: 400/3000 MHz Core speeds (MHz): 1: 2793 2: 2346 3: 777
4: 2755
Device-1: Intel HD Graphics 520 driver: i915 v: kernel bus ID: 00:02.0
Device-2: AMD Opal XT [Radeon R7 M265] driver: radeon v: kernel bus ID: 03:00.0
Display: server: X.Org 1.19.2 driver: ati,modesetting,radeon unloaded: fbdev,vesa
resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 520 (Skylake GT2) v: 4.5 Mesa 13.0.6
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
bus ID: 00:1f.3
Sound Server: ALSA v: k4.9.87-antix.1-amd64-smp
Device-1: Intel Ethernet I219-LM driver: e1000e v: 3.2.6-k port: efa0
bus ID: 00:1f.6
IF: eth1 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: efa0 bus ID: 02:00.0
IF: wlan1 state: up mac: <filter>
Local Storage: total: 353.04 GiB used: 28.87 GiB (8.2%)
ID-1: /dev/sda vendor: SanDisk model: SD8SN8U-256G-1006 size: 238.47 GiB
ID-2: /dev/sdb type: USB vendor: SanDisk model: Ultra size: 114.56 GiB
ID-1: / size: 476.2 MiB used: 338.3 MiB (71.0%) fs: overlay dev: ERR-102
System Temperatures: cpu: 41.0 C mobo: 40.0 C
1: deb http://repo.antixlinux.com/stretch/ stretch main nosystemd nonfree
1: deb http://mirror.fsmg.org.nz/debian/ stretch-updates main contrib non-free
1: deb http://mirror.fsmg.org.nz/debian/ stretch non-free contrib main
2: deb http://security.debian.org/ stretch/updates non-free contrib main
No active apt repos in: /etc/apt/sources.list.d/onion.list
Processes: 213 Uptime: 7h 44m Memory: 7.68 GiB used: 1.25 GiB (16.2%) Init: SysVinit
runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.25
BOOT_IMAGE=/antiX/vmlinuz quiet splash=v disable=lx lang=en_NZ tz=Pacific/Auckland persist_static
==> /etc/live/persist-config.conf <==
AUTOSAVE_MODE="1 Automatic"
==> /etc/apt/sources.list.d/antix.list <==
# deb http://mx.debian.nz/antix/testing/ testing main nosystemd nonfree
# deb http://repo.antixlinux.com/stretch/ stretch main nosystemd nonfree
demo@antix1:~
The command line output above was before reboot with repo changes in effect, the output below is following reboot and the repo has reverted to the original settings again, see below for the output:
demo@antix1:~
Speed: 514 MHz min/max: 400/3000 MHz Core speeds (MHz): 1: 514 2: 500 3: 528 4: 594
bus ID: 00:1f.3
bus ID: 00:1f.6
System Temperatures: cpu: 46.0 C mobo: 42.0 C
1: deb http://mx.debian.nz/antix/stretch/ stretch main nosystemd nonfree
Processes: 214 Uptime: 2m Memory: 7.68 GiB used: 988.2 MiB (12.6%) Init: SysVinit
# deb http://mx.debian.nz/antix/stretch/ stretch main nosystemd nonfree
I think localize-repo is running every live boot.
Your SanDisk Ultra shows a partition overlay dev ERR-102. Suggest you use another USB thumb drive and install fresh with Live USB Maker.rmcg wrote: ↑Tue Oct 16, 2018 11:35 pm Drives:
EDIT: on antiX use Live USB Maker to create a new LiveUSB.
