Icon on Desktop
Icon on Desktop
Hi, I just installed Antix full (space-icevm) on an EeePc 1001, and everything works perfectly. But I have a problem: I can not figure out how to make the connection of an application to the desktop. It's just a trivial thing, but I just can not figure out how to do it. The right mouse button is sufficient in MX, but it does not work here. Can someone help me ? Thanks so much !
Re: Icon on Desktop
should be able to use cntrl+shift+drag from spacefm to the desktop to get a link from spacefm.
you can also hover over any existing desktop item, right click->new -> link and complete the necessary information.
linking tot he desktop is much easier with rox desktop running the desktop icons. just drag and drop from any filemanager
Re: Icon on Desktop
Navigate in the file manager to /usr/share/applications and drag the .desktop file of the app you want to the desktop.
Re: Icon on Desktop
OK, TKS! It's works. With Rox desktop I can drag the desktop file from usr/share/applications to the Desktop.anticapitalista wrote: ↑Thu Sep 06, 2018 4:00 pm Navigate in the file manager to /usr/share/applications and drag the .desktop file of the app you want to the desktop.
Thanks for the lightning response ...!
