can't update antix control centre
#1 Post by asqwerth »
This is a VM of antix17 (admittedly beta3 but kept updated without issue and running on XFCE).
Today's update via Synaptic was unable to update the control-centre-antix package from ver 0.6.5 to 0.6.6.
Was there a change of package that runs control centre? I note there is an uninstalled package called antix-cc-antix in the repo.
I tried sudo apt-get -f install and got:
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  libjs-jquery libjs-sphinxdoc libjs-underscore python-concurrent.futures
  python-livestreamer python-singledispatch
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
sudo dpkg -C didn't turn up any messages or information.
This is more a test VM to try out stuff so it's not the end of the world if the issue cannot be resolved, but I can't believe it's a major thing so would appreciate any help.
Re: can't update antix control centre
#2 Post by anticapitalista »
You will have to wait until live-usb-maker-gui-antix appears in the repo.
I'm just waiting for the repo man to do so.
Return to “antiX”
