meltdown and spectre
CaputAlista
#1 Post by CaputAlista »
i has update my system then i download a script for detecting meltdown and spectre (https://github.com/speed47/spectre-melt ... r/releases) and the report is: <<... Checking for vulnerabilities against running kernel Linux 4.13.0-1-amd64 #1 SMP Debian 4.13.13-1mx17 (2017-11-18) x86_64
CPU is Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
CVE-2017-5753 [bounds check bypass] aka 'Spectre Variant 1'
* Checking count of LFENCE opcodes in kernel: NO
> STATUS: VULNERABLE (only 23 opcodes found, should be >= 70, heuristic to be improved when official patches become available)
CVE-2017-5715 [branch target injection] aka 'Spectre Variant 2'
* Mitigation 1
* Hardware (CPU microcode) support for mitigation: NO
* Kernel support for IBRS: NO
* IBRS enabled for Kernel space: NO
* IBRS enabled for User space: NO
* Mitigation 2
* Kernel compiled with retpoline option: NO
* Kernel compiled with a retpoline-aware compiler: NO
> STATUS: VULNERABLE (IBRS hardware + kernel support OR kernel with retpoline are needed to mitigate the vulnerability)
CVE-2017-5754 [rogue data cache load] aka 'Meltdown' aka 'Variant 3'
* Kernel supports Page Table Isolation (PTI): NO
* PTI enabled and active: NO
> STATUS: VULNERABLE (PTI is needed to mitigate the vulnerability)
A false sense of security is worse than no security at all, see --disclaimer ...>>
also: Found linuxfs file linuxfs in directory /antiX
Found:
1 total live kernel (4.13.0-1-amd64)
1 default live kernel (4.13.0-1-amd64)
0 old live kernels
1 total installed kernel (4.13.0-1-amd64)
0 new installed kernels
No new kernels were found
What I can do?
Re: meltdown and spectre
#2 Post by Jerry3904 »
#3 Post by timkb4cq »
As previously announced on the antiX forums:
https://www.antixforum.com/spectre-and- ... -upgrades/
The available kernels for antiX-17 with meltdown/spectre patches are 4.14.12 and 4.9.75
The available kernels for antiX-16 with meltdown/spectre patches are the 4.9.75.antix.2 kernel now in jessie repo, the 4.4.109 kernel built from Ubuntu source, or the patched Debian kernel (3.16.0-5)
Keep in mind that there are not yet kernel patches available anywhere for all spectre variants and it may be some time before there are.
#4 Post by Jerry3904 »
Oops, didn't see that it was in the antiX forum.
towwire
#5 Post by towwire »
Tim, I have the same as you when using Spectre and Meltdown mitigation detection tool v0.27, but you may find that 2 out of 3 VULNERABLE when using Spectre and Meltdown mitigation detection tool v0.30.
I have the same results with each version's of the tools after updating to kernel Linux 4.9.0-0.bpo.5-amd64 from kernel Linux 4.7.0-0.bpo.1-amd64. As shown here:
$ sudo ./spectre-meltdown-checker.sh
Checking for vulnerabilities against live running kernel Linux 4.9.0-0.bpo.5-amd64 #1 SMP Debian 4.9.65-3+deb9u2~bpo8+1 (2017-01-05) x86_64
> STATUS:  VULNERABLE  (only 25 opcodes found, should be >= 70, heuristic to be improved when official patches become available)
* Mitigation 1
* Mitigation 2
> STATUS:  NOT VULNERABLE  (your CPU vendor reported your CPU model as not vulnerable)
* Kernel supports Page Table Isolation (PTI):  YES
Checking for vulnerabilities against running kernel Linux 4.9.0-0.bpo.5-amd64 #1 SMP Debian 4.9.65-3+deb9u2~bpo8+1 (2017-01-05) x86_64
CPU is AMD A10-7850K Radeon R7, 12 Compute Cores 4C+8G
* Mitigation 1
*     The SPEC_CTRL MSR is available:  NO
*     The SPEC_CTRL CPUID feature bit is set:  NO
* Mitigation 2
#6 Post by Stevo »
Jerry3904 wrote:Oops, didn't see that it was in the antiX forum.
Yet the OP's results are from the MX kernel, not one of antiX's. There's some wires crossed somewhere...
I think the recent intel-microcode update would have changed one of the Spectre results, too. Maybe that hasn't been applied yet?
towwire
#7 Post by towwire »
Oops, sorry I put it in the wrong thread as I was going back and forth between two. Was just trying to show that there are different results between versions of the script.
Here is my APT History, note the two intel-microcode updates.
2018-01-14  09:42:07  remove   linux-image-amd64                         amd64  4.9+80+deb9u2~bpo8+2                 <none>
2018-01-14  09:42:07  remove   linux-headers-amd64                       amd64  4.9+80+deb9u2~bpo8+2                 <none>
2018-01-14  09:38:21  upgrade  linux-image-amd64                         amd64  4.9+80+deb9u2~bpo8+2                 4.9+80+deb9u2~bpo8+2
2018-01-14  09:38:20  upgrade  linux-headers-amd64                       amd64  4.9+80+deb9u2~bpo8+2                 4.9+80+deb9u2~bpo8+2
2018-01-14  09:36:56  install  linux-image-amd64                         amd64  <none>                               4.9+80+deb9u2~bpo8+2
2018-01-14  09:36:51  install  linux-image-4.9.0-0.bpo.5-amd64           amd64  <none>                               4.9.65-3+deb9u2~bpo8+1
2018-01-14  09:36:50  install  linux-headers-amd64                       amd64  <none>                               4.9+80+deb9u2~bpo8+2
2018-01-14  09:36:48  install  linux-kbuild-4.9                          amd64  <none>                               4.9.65-3+deb9u2~bpo8+1
2018-01-14  09:36:48  install  linux-headers-4.9.0-0.bpo.5-amd64         amd64  <none>                               4.9.65-3+deb9u2~bpo8+1
2018-01-14  09:36:42  install  linux-headers-4.9.0-0.bpo.5-common        all    <none>                               4.9.65-3+deb9u2~bpo8+1
2018-01-14  09:32:47  upgrade  mx-packageinstaller-pkglist               all    18.01mx16                            18.02mx16
2018-01-14  09:32:46  upgrade  smtube                                    amd64  17.5.0-0mx150+1                      18.1.0+4.1
2018-01-14  09:32:45  upgrade  cli-shell-utils                           all    0.3.4                                0.3.5
2018-01-14  09:32:45  install  libqt5script5                             amd64  <none>                               5.3.2+dfsg-2
2018-01-13  09:30:21  upgrade  python-libxml2                            amd64  2.9.1+dfsg1-5+deb8u5                 2.9.1+dfsg1-5+deb8u6
2018-01-13  09:30:21  upgrade  intel-microcode                           amd64  3.20171215.1~mx15+1                  3.20180108.1~mx15+1
2018-01-13  09:30:20  upgrade  libxml2                                   amd64  2.9.1+dfsg1-5+deb8u5                 2.9.1+dfsg1-5+deb8u6
2018-01-13  09:30:19  upgrade  libxml2                                   i386   2.9.1+dfsg1-5+deb8u5                 2.9.1+dfsg1-5+deb8u6
2018-01-12  08:03:11  upgrade  xfce4-whiskermenu-plugin                  amd64  1:1.7.3-1mx15+1                      1:1.7.5-0.1~mx15+1
2018-01-12  08:03:10  upgrade  live-usb-maker-gui                        all    0.2.2                                0.2.3
2018-01-11  08:00:30  upgrade  intel-microcode                           amd64  3.20170707.1mx15+1                   3.20171215.1~mx15+1
#8 Post by Stevo »
This is one guy posting on the Alpine Linux developer boards, but it's distressing for older kernels if it's true:
https://lists.alpinelinux.org/alpine-devel/6022.html
#9 Post by Jerry3904 »
Nice summary in today's DistroWatch:
https://distrowatch.com/weekly.php?issue=20180115#qa
Return to “antiX”
