time in conky?- SOLVED
entropyfoe
#1 Post by entropyfoe »
OK I give up. several googles, finding only obscure go no where links, my question is simple.
On my stock AntiX 17 beta 2 fully updated, I want the time at the top to display the seconds.
I am guessing I need to edit the
.conkyrc
I see this stuff, and trying to copy like the edits above , first I try
in the time section I see this ...
# time (format) Local time, see man strftime to get more
%T
So I tried man strftime, but it is not present.
So googling more I added the %T, I saved the file, conky blinked. and still no seconds are displayed.
This must be easy...so how to make the simple change?
Asus PRIME X470-PRO
Nvidia GeForce GT 710
on-board ethernet & sound
Re: time in conky?
#2 Post by asqwerth »
${time %H:%M:%S}
entropyfoe
Re: time in conky?
#3 Post by entropyfoe »
${time %H:%M:%S}
Where do I put that into the config file? With the dollar sign? Do I have to be root to edit this?
And then just save the file?
Asus PRIME X470-PRO
Re: time in conky?
#4 Post by asqwerth »
entropyfoe wrote:${time %H:%M:%S}
No root, just edit .conkyrc and add this command in the section of script that is under TEXT.
The "$" is just to indicate that everything within the braces that follow is part of a conky text command rather than text that is to be displayed as is.
Example from the TEXT portion of an older antiX conky: (the time command is 3rd line from the bottom)
TEXT
${color3}${alignc}antiX
${color8}$alignc${font DejaVu Sans:size=12}${time %I:%M}   $font
${color}${alignc}${time %a %d %b}
${color}${alignc}Uptime: $uptime
${color}${alignc}${exec disp=${DISPLAY#:}; disp=${disp%.[0-9]}; cat $HOME/.desktop-session/desktop-code.$disp 2>/dev/null}
${color}res:${alignr}${color3}${execi 60 xdpyinfo | sed -n -r "s/^\s*dimensions:.*\s([0-9]+x[0-9]+).*/\1/p"}
${color}dpi:${alignr}${color3}${execi 60 sed -nr "s/^\s*Xft.dpi:\s*([0-9]+(x[0-9]+)?).*/\1/p" $HOME/.Xresources | grep "[0-9]" || echo 96}
${color}Automount: ${alignr}${color3}${execi 60 grep -q "^automount=TRUE" $HOME/.desktop-session/automount.conf 2>/dev/null && echo "enabled" || echo "disabled"}
${color}CPU:${alignr}${color3}${cpu}${color}%
${color}Freq:${color3}${alignr}${freq}
${color}$alignr${cpugraph cpu0 30,170 5599cc 5599cc}
${color}Disk:${alignr}${color3}${diskio}
${color}${alignr}${diskiograph 30,170 5599cc 5599cc}${if_up eth0}
${color}eth0 up: $alignr${color3} ${upspeed eth0}
${color}$alignr${upspeedgraph   eth0 30,170 5599cc 5599cc}
${color}eth0 down: $alignr${color3} ${downspeed eth0}
${color2}$alignr${downspeedgraph eth0 30,170  5599cc 5599cc}${endif}${if_up eth1}
${color}eth1 up: $alignr${color3} ${upspeed eth1}
${color}$alignr${upspeedgraph   eth1 30,170 5599cc 5599cc}
${color}eth1 down: $alignr${color3} ${downspeed eth1}
${color2}$alignr${downspeedgraph eth1 30,170  5599cc 5599cc}${endif}${if_up wlan0}
${color}wlan0 up: $alignr${color3} ${upspeed wlan0}
${color2}$alignr${upspeedgraph   wlan0 30,170 5599cc 5599cc}
${color}wlan0 down: $alignr${color3} ${downspeed wlan0}
${color2}$alignr${downspeedgraph wlan0 30,170 5599cc 5599cc}${endif}${if_up wlan1}
${color}wlan1 up: $alignr${color3} ${upspeed wlan1}
${color2}$alignr${upspeedgraph   wlan1 30,170 5599cc 5599cc}
${color}wlan1 down: $alignr${color3} ${downspeed wlan1}
${color2}$alignr${downspeedgraph wlan1 30,170 5599cc 5599cc}${endif}
${color}${alignr}${color8}Used / Total
${color}RAM:${alignr}$mem ${color3} /${color} $memmax
${color}Swap:${alignr}$swap ${color3} /${color} $swapmax
${color}/ Disk:${alignr}${fs_used /} ${color3} /${color} ${fs_size /}
The time is:${alignr}${time %H:%M:%S}
${color3}${alignc}${execi 1000 persist-enabled}
${execi 1000 acpi 2>/dev/null | grep -q . && echo "Batt: "}${execi 10 acpi -b 2>/dev/null | cut -d" " -f3,4 | sed 's/,$//'}
entropyfoe
Re: time in conky?
#5 Post by entropyfoe »
Thanks asqwerth
That worked.
I am doing some experimenting for hardware stability.
My MX 16.1 reboots spontaneously every few days. I dual boot with antiX 17 to see if this is a latent hardware problem or a software issue.
Thanks, it looks like I may lean into some more conky customization, I never really messed with it before.
Asus PRIME X470-PRO
Return to “antiX”
