antiX-17-pre-rc1 iso - 16 September 2017.
namida12
#1 Post by namida12 »
Live CD posting.
demo@antix1:~
$ inxi -F
System:    Host: antix1 Kernel: 4.10.5-antix.3-amd64-smp x86_64 (64 bit) Desktop: IceWM 1.4.2
           Distro: antiX-17.pre-rc1_x64-full Heather Heyer 16 September 2017
Machine:   Device: laptop Mobo: MSI model: B350M GAMING PRO (MS-7A39) v: 1.0 UEFI: American Megatrends v: 2.30 date: 03/24/2017
CPU:       Quad core AMD Ryzen 5 1500X (-HT-MCP-) cache: 2048 KB
           clock speeds: max: 3500 MHz 1: 1550 MHz 2: 1550 MHz 3: 1550 MHz 4: 1550 MHz 5: 1550 MHz 6: 1550 MHz
           7: 1550 MHz 8: 1550 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RV670 [Radeon HD 3690/3850]
           Display Server: X.Org 1.19.2 drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Gallium 0.4 on AMD RV670 (DRM 2.49.0 / 4.10.5-antix.3-amd64-smp, LLVM 3.9.1)
           GLX Version: 3.3 Mesa 13.0.6
Audio:     Card-1 Advanced Micro Devices [AMD] Device 1457 driver: snd_hda_intel
           Card-2 Advanced Micro Devices [AMD/ATI] RV670/680 HDMI Audio [Radeon HD 3690/3800 Series]
           Sound: Advanced Linux Sound Architecture v: k4.10.5-antix.3-amd64-smp
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
           IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 30:9c:23:00:fd:16
Drives:    HDD Total Size: 250.1GB (1.6% used)
           ID-1: /dev/sda model: Samsung_SSD_850 size: 250.1GB
Partition: ID-1: / size: 13G used: 817M (7%) fs: overlay dev: N/A
           ID-2: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: No active sensors found. Have you configured your sensors yet? mobo: N/A gpu: 87.0
Info:      Processes: 240 Uptime: 23 min Memory: 962.7/16063.8MB Client: Shell (bash) inxi: 2.3.21
Have added GIMP, and Google Chrome. Will play with live mode for a while then install. Still shows 8 cores on a Quad, and Motherboard is still ID as a Laptop other than that this seems quite stable. Very good Job this far, tipping me hat....
JR
namida12
Re: antiX-17-pre-rc1 iso - 16 September 2017.
#2 Post by namida12 »
Sound was muted on panel. downloaded Pusleaudio from package installer still no sound.
Went back to 17 -B1 posting and tried previous suggestion:
demo@antix1:~
$ alsa-set-default-card
sed: can't read /home/demo/.asoundrc: No such file or directory
demo@antix1:~
Popup box appeared showing HDMI as the default, and it allowed me to choose the generic sound card. Again I have sound.
Wired internet was available on boot from dvd.
Screen size was no problem with older AMD/ATI video card
JR
entropyfoe
Re: antiX-17-rc1 iso - 16 September 2017.
#3 Post by entropyfoe »
RC1 is looking good for me.
{aside from my efforts to get kernel 4.13 working with video]
BTW, I was not able to find a md5 for the RC1. Does anyone have this, it is not in the read-me notes.
Wired ethernet works , so per anti's request I tried pulling out the Ethernet cable, and replugging. On my home network, the re-connection was immediate with no problems.
USB sticks are automounted just fine and contents are openable.
I did synaptic updates, accepted all , rebooted, no problems.
Added a dozen applications with synaptic, all good.
Suspend to RAM and waking works fine.
Changed wallpapers, themes, all seems normal and functioning.
Youtube videos play OTB.
With sound working after switching to the generic selection.
So far, a good install from USB, suitable for a daily driver. I will continue my system stability checking with antix 17 rc1 on this Ryzen hardware.
Host: Ryzen Kernel: 4.10.5-antix.3-amd64-smp x86_64 bits: 64
           Distro: antiX-17.rc1_x64-full Heather Heyer 6 October 2017
Machine:   Device: desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x serial: N/A
           UEFI [Legacy]: American Megatrends v: 0902 date: 09/08/2017
CPU:       Hexa core AMD Ryzen 5 1600X Six-Core (-HT-MCP-) cache: 3072 KB
           clock speeds: max: 3600 MHz 1: 2200 MHz 2: 2200 MHz 3: 2200 MHz 4: 2200 MHz
           5: 2200 MHz 6: 2200 MHz 7: 2200 MHz 8: 2200 MHz 9: 2200 MHz 10: 2200 MHz
           11: 2200 MHz 12: 2200 MHz
Graphics:  Card: NVIDIA GK208 [GeForce GT 710B]
           Display Server: X.Org 1.19.2 driver: nvidia Resolution: 1920x1080@60.00hz
           OpenGL: renderer: GeForce GT 710/PCIe/SSE2 version: 4.5.0 NVIDIA 384.90
           Card-2 NVIDIA GK208 HDMI/DP Audio Controller driver: snd_hda_intel
Network:   Card: Intel I211 Gigabit Network Connection driver: igb
           IF: eth0 state: up speed: 100 Mbps duplex:
Drives:    HDD Total Size: 2250.5GB (0.9% used)
           ID-1: /dev/sda model: WDC_WD2002FAEX size: 2000.4GB
           ID-2: /dev/nvme0n1 model: Samsung_SSD_960_EVO_250GB size: 250.1GB
Partition: ID-1: / size: 101G used: 3.9G (4%) fs: ext4 dev: /dev/nvme0n1p4
           ID-2: swap-1 size: 17.83GB used: 0.00GB (0%) fs: swap dev: /dev/nvme0n1p2
Sensors:   System Temperatures: cpu: N/A mobo: N/A gpu: 37C
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 279 Uptime: 14 min Memory: 521.3/16046.7MB
           Client: Shell (bash) inxi: 2.3.40
Asus PRIME X470-PRO
Nvidia GeForce GT 710
on-board ethernet & sound
BitJam
#4 Post by BitJam »
From the files I downloaded:
a86e79b66176e7ea8c9b31f775d69907  antiX-17.rc1_386-full.iso
2399c021f9d16f2c5bfb72b1886949fb  antiX-17.rc1_x64-full.iso
-- Richard Feynman
entropyfoe
#5 Post by entropyfoe »
Thanks BitJam, I will check my download tonight (on a Win 7 machine now), that md5 looks familiar, I seem to recall the 49fb at the end for some reason.
Asus PRIME X470-PRO
Return to “antiX”
