antiX-17-b3-full, base and core-libre versions available for public testing
* Beta3 has some bug fixes and a new kernel for 64 bit isos.
* Still systemd and libsystemd free
* eudev rather than udev
I have uploaded the base and core-libre versions for people to test. The base version includes IceWM and fits on a cd. No libreoffice though.
Known issues since a fix has still not been found.
* IceWM and jwm task bar icon for streamlight is half size
* IceWM themes do not increase size of icons
* Conky blur when switching themes in IceWM
Enjoy!
Get files from here:
https://sourceforge.net/projects/antix- ... /antiX-17/
anticapitalista, 18 August 2017, Thessaloniki
Enjoy!
- entropyfoe
Re: antiX-17-b3-full, base and core-libre versions available for public testing
What is the new kernel on the 64 bit?
I did not see the name or number written anywhere.
Asus PRIME X470-PRO
Nvidia GeForce GT 710
on-board ethernet & sound
4.10.5-antix.3-amd64-smpentropyfoe wrote:What is the new kernel on the 64 bit?
Lost Sound -
Had sound icon on lower right panel, fumble with mouse trying to increase sound to 100% and muted sound accidentally, could not find a method or tool to open sound, then pressed quit that made the sound Icon disappear along with sound. <--Operator error Restarted machine still no sound.
Tried download pulse audio, but have been unable getting it to work, as I did in Beta 2, nothing I am able to do seems to be working to get sound activated, currently completely out of my element.
Found Mute M control and was able to unmute Pulseaudio in the Volume control.
Unmuted pulseaudio in the Pulseaudio Volume control and again have sound, with lots of volume that was lacking using alsa sound.
It seems Pulse audio has the ability to provide increased volume levels, but does not have the nice sound icon to easily control the volume like alsa sound.
In this system using alsa on some videos the audio volume is not sufficient to be heard/understood. Pulse Audio provides the volume that was lacking, just took more blind experimentation to get it to work.
Revision: the sound icon appeared on panel again, can it control Pulseaudio it seems to have the capability to effect the volume levels.
JR
green245@green245:~
$ inxi -F
System: Host: green245 Kernel: 4.10.5-antix.3-amd64-smp x86_64 (64 bit) Desktop: IceWM 1.4.2
Distro: antiX-17.b3_x64-full Heather Heyer 18 August 2017
Machine: Device: laptop Mobo: MSI model: B350M GAMING PRO (MS-7A39) v: 1.0
UEFI [Legacy]: American Megatrends v: 2.30 date: 03/24/2017
CPU: Quad core AMD Ryzen 5 1500X (-HT-MCP-) cache: 2048 KB
clock speeds: max: 3500 MHz 1: 1550 MHz 2: 1550 MHz 3: 1550 MHz 4: 1550 MHz 5: 1550 MHz 6: 1550 MHz
7: 1550 MHz 8: 1550 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] RV670 [Radeon HD 3690/3850]
Display Server: X.Org 1.19.2 drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
Resolution: 1920x1080@60.00hz
GLX Renderer: Gallium 0.4 on AMD RV670 (DRM 2.49.0 / 4.10.5-antix.3-amd64-smp, LLVM 3.9.1)
GLX Version: 3.3 Mesa 13.0.6
Audio: Card-1 Advanced Micro Devices [AMD] Device 1457 driver: snd_hda_intel
Card-2 Advanced Micro Devices [AMD/ATI] RV670/680 HDMI Audio [Radeon HD 3690/3800 Series]
Sound: Advanced Linux Sound Architecture v: k4.10.5-antix.3-amd64-smp
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 30:9c:23:00:fd:16
Drives: HDD Total Size: 250.1GB (4.1% used)
ID-1: /dev/sda model: Samsung_SSD_850 size: 250.1GB
Partition: ID-1: / size: 14G used: 4.4G (34%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 206G used: 1.3G (1%) fs: ext4 dev: /dev/sda3
ID-3: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: No active sensors found. Have you configured your sensors yet? mobo: N/A gpu: 85.0
Info: Processes: 252 Uptime: 28 min Memory: 618.5/16066.0MB Client: Shell (bash) inxi: 2.3.21
green245@green245:~
JR
Is there a zsync download (think it would be antiX-17.b3_x64-full.iso.zsync) available? I don't see one at the sourceforge link.
Done!kmathern wrote:Is there a zsync download (think it would be antiX-17.b3_x64-full.iso.zsync) available? I don't see one at the sourceforge link.
Thankyou.anticapitalista wrote:Done!kmathern wrote:Is there a zsync download (think it would be antiX-17.b3_x64-full.iso.zsync) available? I don't see one at the sourceforge link.
p.s. also what's the md5sum for antiX-17.b3_x64-full.iso ?
5a06e9ca9113c5b9a156a8fe845d974c antiX-17.b3_x64-full.iso
Apologies for what is likely to be a basic question, but my ethernet connection does not appear to autoconnect. Every time I rebooted up I had to to reconnect. I've tried doing the reconnection both from ceni and from the wicd icon in notification area (I'm using XFCE).
I also tried ticking the wicd option "always switch to wired connection when available".
But I'm still having to manually connect everytime I reboot and log in again.
Is that really the default situation? To require manual connecting?
Details: installed just last night on Virtualbox, added XFCE, still using the SLIM desktop manager.
BTW, in antiXCC I had previously overlooked trying the wicd settings because it was labelled "connect wirelessly") .
