Hello,
Can the timeout for ifup'ing eth0 & wlan0 be shortened during bootup (pre-X) ?
thanks
timeout for eth0 & wlan0 under antiX16 is long
Linux user since 1999, on-line 1993
Dtop#1: XU20 AMD-FX6300, GT730
Dtop#2: MX19 AM3ATH2X2, GT218-8400
Ltop#1: MX21 T500
Ltop#2: MX19 T440
Ltop#3: MX19 NC6400
Ltop#4: XU18 NC4400
Ltop#5: Sparky32 T30
Ltop#6: MX21 Acer E5
Ltop#1: MX21 T500
Ltop#2: MX19 T440
Ltop#3: MX19 NC6400
Ltop#4: XU18 NC4400
Re: timeout for eth0 & wlan0 under antiX16 is long
well, give us the "inxi -F" for that system please.
System: Host: antix16 Kernel: 4.4.10-antix.1-486-smp i686 (32 bit) Console: tty 1
Distro: antiX-16.2_386-full Berta Cáceres 15 June 2017
Machine: Device: desktop Mobo: Gigabyte model: GA-78LMT-USB3 6.0 v: x.x BIOS: Award v: F2 date: 11/25/2014
CPU: Quad core AMD FX-4300 (-MCP-) cache: 8192 KB
clock speeds: max: 3800 MHz 1: 3400 MHz 2: 1800 MHz 3: 1800 MHz 4: 1800 MHz
Graphics: Card: NVIDIA G71 [GeForce 7900 GT/GTO]
Display Server: X.org 1.19.2 driver: (unloaded: nvidia)
tty size: 100x37 Advanced Data: N/A out of X
Audio: Card Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA) driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.4.10-antix.1-486-smp
Network: Card-1: Ralink RT5392 PCIe Wireless Network Adapter driver: rt2800pci
IF: wlan0 state: up mac: xxxxxx
Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
driver: r8169
IF: eth0 state: down mac: xxxx
Drives: HDD Total Size: 128.0GB (4.2% used)
ID-1: /dev/sda model: Patriot_Torch_SE size: 128.0GB
Partition: ID-1: / size: 5.1G used: 5.0G (100%) fs: ext4 dev: /dev/sda3
Sensors: System Temperatures: cpu: 13.5C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 132 Uptime: 1 min Memory: 74.9/3282.5MB Init: SysVinit runlevel: 5
Client: Shell (bash) inxi: 2.3.21
Ltop#1: MX21 T500
Ltop#2: MX19 T440
Ltop#3: MX19 NC6400
Ltop#4: XU18 NC4400
Ltop#1: MX21 T500
Ltop#2: MX19 T440
Ltop#3: MX19 NC6400
Ltop#4: XU18 NC4400
if you set up your connection with ceni instead of wicd, it should come up faster.
