[ 203.399]
X.Org X Server 1.19.2
Release Date: 2017-03-02
[ 203.401] X Protocol Version 11, Revision 0
[ 203.401] Build Operating System: Linux 4.10.1+ i686 Debian
[ 203.402] Current Operating System: Linux antix16 4.4.10-antix.1-486-smp #1 SMP Thu Feb 23 19:55:09 EET 2017 i686
[ 203.402] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.4.10-antix.1-486-smp root=UUID=9a2e5049-bafe-4628-a4b6-9a3ff4405e76 ro vga=788 quiet
[ 203.404] Build Date: 04 March 2017 06:34:44AM
[ 203.404] xorg-server 2:1.19.2-1.0nosystemd1 (https://www.debian.org/support)
[ 203.404] Current version of pixman: 0.34.0
[ 203.405] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 203.405] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 203.406] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 18 12:14:27 2017
[ 203.407] (==) Using config file: "/etc/X11/xorg.conf"
[ 203.407] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 203.407] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 203.408] (==) ServerLayout "Layout0"
[ 203.408] (**) |-->Screen "Screen0" (0)
[ 203.408] (**) | |-->Monitor "Monitor0"
[ 203.408] (**) | |-->Device "Device0"
[ 203.408] (**) |-->Input Device "Keyboard0"
[ 203.408] (**) |-->Input Device "Mouse0"
[ 203.408] (==) Automatically adding devices
[ 203.408] (==) Automatically enabling devices
[ 203.408] (==) Automatically adding GPU devices
[ 203.408] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 203.408] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 203.408] Entry deleted from font path.
[ 203.408] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 203.408] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 203.408] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
built-ins
[ 203.408] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 203.408] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[ 203.408] (WW) Disabling Keyboard0
[ 203.408] (WW) Disabling Mouse0
[ 203.408] (II) Loader magic: 0x803506c0
[ 203.408] (II) Module ABI versions:
[ 203.408] X.Org ANSI C Emulation: 0.4
[ 203.408] X.Org Video Driver: 23.0
[ 203.408] X.Org XInput driver : 24.1
[ 203.408] X.Org Server Extension : 10.0
[ 203.408] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 203.409] (--) PCI:*(0:1:0:0) 10de:0291:10de:c560 rev 161, Mem @ 0xfa000000/16777216, 0xd0000000/268435456, 0xfb000000/16777216, I/O @ 0x0000cf00/128, BIOS @ 0x????????/131072
[ 203.409] (II) LoadModule: "glx"
[ 203.409] (II) Loading /usr/lib/xorg/modules/linux/libglx.so
[ 203.428] (II) Module glx: vendor="NVIDIA Corporation"
[ 203.428] compiled for 4.0.2, module version = 1.0.0
[ 203.428] Module class: X.Org Server Extension
[ 203.428] (II) NVIDIA GLX Module 304.135 Tue Jan 17 15:15:59 PST 2017
[ 203.428] (II) LoadModule: "nvidia"
[ 203.429] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 203.429] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 203.429] compiled for 4.0.2, module version = 1.0.0
[ 203.429] Module class: X.Org Video Driver
[ 203.429] (II) NVIDIA dlloader X Driver 304.135 Tue Jan 17 14:55:47 PST 2017
[ 203.429] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 203.429] (++) using VT number 1
[ 203.429] (II) Loading sub module "fb"
[ 203.429] (II) LoadModule: "fb"
[ 203.429] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 203.429] (II) Module fb: vendor="X.Org Foundation"
[ 203.429] compiled for 1.19.2, module version = 1.0.0
[ 203.429] ABI class: X.Org ANSI C Emulation, version 0.4
[ 203.429] (II) Loading sub module "wfb"
[ 203.429] (II) LoadModule: "wfb"
[ 203.430] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 203.430] (II) Module wfb: vendor="X.Org Foundation"
[ 203.430] compiled for 1.19.2, module version = 1.0.0
[ 203.430] ABI class: X.Org ANSI C Emulation, version 0.4
[ 203.430] (II) Loading sub module "ramdac"
[ 203.430] (II) LoadModule: "ramdac"
[ 203.430] (II) Module "ramdac" already built-in
[ 203.430] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 203.430] (==) NVIDIA(0): RGB weight 888
[ 203.430] (==) NVIDIA(0): Default visual is TrueColor
[ 203.430] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 203.430] (**) NVIDIA(0): Enabling 2D acceleration
[ 203.430] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0. Please
[ 203.430] (EE) NVIDIA(0): check your system's kernel log for additional error
[ 203.430] (EE) NVIDIA(0): messages and refer to Chapter 8: Common Problems in the
[ 203.430] (EE) NVIDIA(0): README for additional information.
[ 203.430] (EE) NVIDIA(0): Failed to initialize the NVIDIA graphics device!
[ 203.430] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 203.430] (II) UnloadModule: "nvidia"
[ 203.430] (II) UnloadSubModule: "wfb"
[ 203.430] (II) UnloadSubModule: "fb"
[ 203.430] (EE) Screen(s) found, but none have a usable configuration.
[ 203.430] (EE)
Fatal server error:
[ 203.430] (EE) no screens found(EE)
[ 203.430] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 203.430] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 203.430] (EE)
[ 203.431] (EE) Server terminated with error (1). Closing log file.
Linux user since 1999, on-line 1993
Dtop#1: XU20 AMD-FX6300, GT730
Dtop#2: MX19 AM3ATH2X2, GT218-8400
Ltop#1: MX21 T500
Ltop#2: MX19 T440
Ltop#3: MX19 NC6400
Ltop#4: XU18 NC4400
Ltop#5: Sparky32 T30
Ltop#6: MX21 Acer E5
