I have discovered how to eject a mounted USB flash drive with the small icon on the lower left of the screen (between the show desktop and workspace 1 icons), and after the flash drive is inserted it will automount. What I have not discovered, is if I accidentally close the USB Flash Drive window where do I find the flash drive and reopen the index window that I just closed.
The File icon on the upper left section desktop does not show the USB Flash drive stick as MX does when looking for the USB Stick. Nor can I open the USB Flash drive from the control center (Disc> Mount Connected Devices). I am certain there is a simple method to reopen the closed file menu of the USB Flash Stick, but can't find this information in the help files.
At a loss?
JR
Solved - USB Flash Stick (mount and unmount)
Re: USB Flash Stick (mount and unmount)
Navigate your file manager to /media.
Thanks, had previously done that 10-or-20 times with no success, but now found the flash drive. Thank you, i just did not go far enough needed one more step, open my green244 folder..dolphin_oracle wrote:Navigate your file manager to /media.
Left click on File icon on desktop upper left corner file icon. Up arrow to parent directory> up arrow to parent directory> open media folder> open green244 folder>
