antiX-17-a2 32bit - amdgpu driver segfaults
kmathern
#1 Post by kmathern »
With antiX-17-a2 32bit I'm getting segfaults when using the amdgpu driver.
My hardware can use either the radeon driver or the amdgpu driver, it uses radeon driver by default.
From the limited testing I've done, it appears to be working okay when using the radeon driver.
I can get it to use the amdgpu driver in a liveusb session by adding the following cheats: radeon.modeset=0 xorg=amdgpu
It seems to boot to the desktop okay with those cheats, and several of the menu entries I've tried for the various apps seem to work okay, but trying to run firefox and also `inxi -F` or `inxi -G` causes X to crash and sends me back to the slim login. In the case of inxi commands, X crashes when I run them as the non-root user (demo), X doesn't crash when I run the inxi commands as root.
Here's the inxi -F output when run as root:
System:    Host: antix1 Kernel: 4.10.1-antix.1-486-smp i686 (32 bit gcc: 6.3.0)
           Desktop: IceWM 1.3.8+mod+20161220 dm: slim
           Distro: antiX-17.a2_386-full keerfa 19 March 2017
Machine:   Device: desktop Mobo: Gateway model: SX2185 serial: DBGELCN00235181F2830A1
           UEFI: American Megatrends v: P11-A4 date: 09/17/2013
CPU:       Dual core AMD E1-2500 APU with Radeon HD Graphics (-MCP-) cache: 2048 KB
           flags: (lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 5589
           clock speeds: min/max: 800/1400 MHz 1: 1200 MHz 2: 1200 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Kabini [Radeon HD 8240 / R3 Series]
           bus-ID: 00:01.0 chip-ID: 1002:9838
           Display Server: X.org 1.19.2 driver: amdgpu
           tty size: 90x28 Advanced Data: N/A for root
Audio:     Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
           driver: snd_hda_intel bus-ID: 00:14.2 chip-ID: 1022:780d
           Card-2 Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio
           driver: snd_hda_intel bus-ID: 00:01.1 chip-ID: 1002:9840
           Sound: Advanced Linux Sound Architecture v: k4.10.1-antix.1-486-smp
Network:   Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 01:00.0 chip-ID: 10ec:8168
           IF: eth0 state: down mac: f8:0f:41:ac:77:6f
Drives:    HDD Total Size: 502.1GB (3.9% used)
           ID-1: /dev/sda model: ST500DM002 size: 500.1GB serial: W3T26NVP
           ID-2: USB /dev/sdb model: Cruzer size: 2.0GB serial: 0572700EFE224B8C-0:0
Partition: ID-1: / size: 1.8G used: 1.2M (1%) fs: overlay dev: N/A
           ID-2: swap-1 size: 8.86GB used: 0.00GB (0%) fs: swap dev: /dev/sda6
           ID-3: swap-2 size: 10.74GB used: 0.00GB (0%) fs: swap dev: /dev/sda23
Sensors:   System Temperatures: cpu: 43.2C mobo: N/A gpu: 43.0
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 144 Uptime: 2 min Memory: 95.4/2286.9MB
           Init: SysVinit v: 2.88 runlevel: 5 default: 5 Gcc sys: 6.3.0
           Client: Shell (bash 4.4.111 running in lxterminal) inxi: 2.3.8
And here's a tail of /var/log/Xorg.0.log
[  4020.516] (II) AMDGPU(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[  4020.516] (II) AMDGPU(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[  4020.516] (II) AMDGPU(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[  4020.516] (II) AMDGPU(0): Modeline "1280x720"x60.0   74.48  1280 1336 1472 1664  720 721 724 746 -hsync +vsync (44.8 kHz e)
[  4020.516] (II) AMDGPU(0): Modeline "1600x900"x60.0  119.00  1600 1696 1864 2128  900 901 904 932 -hsync +vsync (55.9 kHz e)
[  4020.516] (II) AMDGPU(0): Modeline "1280x800"x0.0   83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync (49.7 kHz e)
[  4020.670] (EE)
[  4020.670] (EE) Backtrace:
[  4020.670] (EE) 0: /usr/lib/xorg/Xorg (xorg_backtrace+0x52) [0x80297e02]
[  4020.670] (EE) 1: /usr/lib/xorg/Xorg (0x800f1000+0x1aadc2) [0x8029bdc2]
[  4020.670] (EE) 2: linux-gate.so.1 (__kernel_rt_sigreturn+0x0) [0xb772ccf0]
[  4020.670] (EE)
[  4020.670] (EE) Segmentation fault at address 0x0
[  4020.670] (EE)
Fatal server error:
[  4020.670] (EE) Caught signal 11 (Segmentation fault). Server aborting
[  4020.670] (EE)
[  4020.670] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[  4020.671] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[  4020.671] (EE)
[  4020.671] (II) AIGLX: Suspending AIGLX clients for VT switch
[  4020.732] (EE) Server terminated with error (1). Closing log file.
Return to “antiX”
