I installed KDE light in AntiX 15.
It can't be logged into from slim.
I wonder if I missed a prompt somewhere in the metapackage installer to install a different login manager?
Is there somewhere that I can change slim to log in KDE light? It doesn't look like it to me.
I think I might have to install kdm or gdm and switch login managers when I want to use KDE.
Any thoughts on this?
Thanks
Slim won't login KDE light in AntiX 15
Re: Slim won't login KDE light in AntiX 15
I installed kdm and got the problems worked out.
Mark this solved.
Mark this solved.
This place seems to be dead tonight.
Is everybody getting ready for the weekend?
- uncle mark
I just installed antiX and added KDE myself, but it's past my bedtime as it is. Will play with it over the long weekend. Looks pretty sweet starting out.duane wrote:This place seems to be dead tonight.
Acer Aspire 5250 -- MX 21 KDE
- Gordon Cooper
That will depend upon where you live. Down under (Here) the weekend has half gone and I'mduane wrote:This place seems to be dead tonight.
getting ready to cook supper.
Do that by clicking on the green check mark on your first post.Mark this solved.
FWIW, the topic of putting KDE over MX (though not antiX IIRC) has been discussed many times on the Forum, and detailed directions are now in the Wiki:
http://www.mepiscommunity.org/wiki/syst ... n-mx-linux
I have seen this question come up on the antiX Forum, so just added a warning to install kdm to the Wiki entry.
- uncle mark
Necessary when installing kde-lite, but it's not with kde-standard -- kdm was included.Jerry3904 wrote:I have seen this question come up on the antiX Forum, so just added a warning to install kdm to the Wiki entry.
On my MX-14 install I don't need kdm to login into KDE4, lightdm works fine.
So maybe you just need kdm if you install KDE4 on antiX-15.
That's my understanding, and that's how I just rewrote the Wiki entry. Not sure about UM's comment, so just said "some (clueless) users"...So maybe you just need kdm if you install KDE4 on antiX-15.
I was able to fiddle around with some stuff in a antiX-15 live session and it now logs in to KDE4 using slim (the kdm package isn't installed).Jerry3904 wrote:That's my understanding, and that's how I just rewrote the Wiki entry. Not sure about UM's comment, so just said "some (clueless) users"...So maybe you just need kdm if you install KDE4 on antiX-15.
But I changed several files, so I'm not exactly sure which changes were the key.
