I didn't really come up with anything on the install disk.
But I have this bug on antiX15 running from my hard drive partition installed.
It's hard to find bugs in this distro. It seems to work so well.
But I was flipping back and forth picking "alternate desktops' from a running desktop
using the menu as my local user. Everything seemed to work fine until I noticed
that my touchpad scroll wasn't working anymore in Google chrome.
Wow! So, I logged out and logged back in and everything was running again as it should.
Anyway, I thought that was kind of weird...
Charlie
antiX15 beta issue.
Re: antiX15 beta issue.
out of curiosity, did the scroll quit working in other apps, or just in chrome? and was it a particular "alternate desktop" or did this condition appear in multiples (ie: jwm, icewm, or fluxbox).kd5ob wrote:I didn't really come up with anything on the install disk.
Charlie
DO,,, Let me do a comprehensive test here.
I also have syndaemon -d -t &
it's in the .icewm/startup file as i said, I'm using this touchpad.
Let me beat it up and I'll tell you. hang on DO.
Charlie
Charlie
If you are relying on that daemon for your TouchPad to work then of course it is not going to work with other window managers when you switch because you only have it in icewm startup. I would suggest to make it work with all window managers place it in the session startup at / etc / desktop-session / startup. That way if will start on session building for any window manager rather than one.
DO and everybody..
Okay,, I banged on it for about 30 minutes and couldn't get it to do it until I hit
rox-jwm . When I went to rox-jwm I also lost my right click on the screen anywheres menu of applications.
And I'd switch back to space-jwm or must jwm and it would all get better.
WOW! I couldn't even select my window here to type when I tried it again rox-jwm!
And it even seemed to interfer with conky. Get back out of rox-jwn and go to any other desktop
and everything returns to normal.
I didn't see any touchpad, conky, or right click menu problems with any other desktop but rox-jwm.
Everything worked good. look at this PS AX I've done after all this testing.
As you will see 29018 ? Ss 0:00 syndaemon -d -t -=-------- it's still running just fine.
I don't know if it's still working just fine but it should be.
Which brings me to another question/issue. If syndaemon is there but isn't running right anymore and needed
to actually be restarted, then maybe we need some community startup area which will track the PID's of these things
and restart them for users as they move from desktop to desktop to desktop.... Just thinking out loud here..
Charlie
PID TTY STAT TIME COMMAND
1 ? Ss 0:01 init [5]
2 ? S 0:00 [kthreadd]
3 ? S 1:02 [ksoftirqd/0]
5 ? S< 0:00 [kworker/0:0H]
7 ? S 1:00 [rcu_sched]
8 ? S 0:00 [rcu_bh]
9 ? S 0:00 [migration/0]
10 ? S 0:00 [watchdog/0]
11 ? S 0:00 [watchdog/1]
12 ? S 0:00 [migration/1]
13 ? S 0:04 [ksoftirqd/1]
15 ? S< 0:00 [kworker/1:0H]
16 ? S 0:00 [watchdog/2]
17 ? S 0:00 [migration/2]
18 ? S 0:02 [ksoftirqd/2]
20 ? S< 0:00 [kworker/2:0H]
21 ? S 0:00 [watchdog/3]
22 ? S 0:00 [migration/3]
23 ? S 0:03 [ksoftirqd/3]
25 ? S< 0:00 [kworker/3:0H]
26 ? S 0:00 [watchdog/4]
27 ? S 0:00 [migration/4]
28 ? S 0:01 [ksoftirqd/4]
30 ? S< 0:00 [kworker/4:0H]
31 ? S 0:00 [watchdog/5]
32 ? S 0:00 [migration/5]
33 ? S 0:03 [ksoftirqd/5]
35 ? S< 0:00 [kworker/5:0H]
36 ? S 0:00 [watchdog/6]
37 ? S 0:00 [migration/6]
38 ? S 0:01 [ksoftirqd/6]
40 ? S< 0:00 [kworker/6:0H]
41 ? S 0:00 [watchdog/7]
42 ? S 0:00 [migration/7]
43 ? S 0:03 [ksoftirqd/7]
45 ? S< 0:00 [kworker/7:0H]
46 ? S< 0:00 [khelper]
47 ? S 0:00 [kdevtmpfs]
48 ? S< 0:00 [netns]
49 ? S 0:00 [khungtaskd]
50 ? S< 0:00 [writeback]
51 ? SN 0:00 [ksmd]
52 ? SN 0:00 [khugepaged]
53 ? S< 0:00 [crypto]
54 ? S< 0:00 [kintegrityd]
55 ? S< 0:00 [bioset]
56 ? S< 0:00 [kblockd]
58 ? S 0:04 [kswapd0]
59 ? S 0:00 [fsnotify_mark]
65 ? S< 0:00 [kthrotld]
66 ? S< 0:00 [ipv6_addrconf]
68 ? S< 0:00 [deferwq]
109 ? S< 0:00 [acpi_thermal_pm]
113 ? S 0:00 [khubd]
121 ? S< 0:00 [ata_sff]
126 ? S 0:00 [scsi_eh_0]
127 ? S< 0:00 [scsi_tmf_0]
128 ? S 0:00 [scsi_eh_1]
129 ? S< 0:00 [scsi_tmf_1]
130 ? S 0:00 [scsi_eh_2]
131 ? S< 0:00 [scsi_tmf_2]
132 ? S 0:00 [scsi_eh_3]
133 ? S< 0:00 [scsi_tmf_3]
134 ? S 0:00 [scsi_eh_4]
135 ? S< 0:00 [scsi_tmf_4]
136 ? S 0:00 [scsi_eh_5]
137 ? S< 0:00 [scsi_tmf_5]
151 ? S< 0:00 [kworker/0:1H]
153 ? S< 0:00 [kworker/1:1H]
155 ? S< 0:01 [kworker/3:1H]
164 ? S< 0:00 [bioset]
166 ? S< 0:03 [kworker/5:1H]
167 ? S< 0:00 [kworker/7:1H]
179 ? S< 0:00 [xfsalloc]
180 ? S< 0:00 [xfs_mru_cache]
181 ? S< 0:00 [xfslogd]
186 ? S< 0:00 [kworker/2:1H]
187 ? S< 0:00 [kworker/4:1H]
191 ? S< 0:00 [xfs-data/sda2]
192 ? S< 0:00 [xfs-conv/sda2]
193 ? S< 0:00 [xfs-cil/sda2]
194 ? S 0:28 [xfsaild/sda2]
264 ? S< 0:00 [kworker/6:1H]
379 ? Ss 0:00 udevd --daemon
440 ? S< 0:00 [hd-audio0]
453 ? S 0:00 [kworker/1:2]
487 ? S< 0:00 [kpsmoused]
490 ? S< 0:00 [cfg80211]
547 ? S< 0:00 [kvm-irqfd-clean]
642 ? S< 0:00 [kmemstick]
643 ? S 0:02 [rtsx_usb_ms_4]
656 ? S 0:00 [kworker/u16:1]
1583 ? Sl 0:03 conky
1824 ? Ss 0:00 /usr/sbin/uuidd
1862 ? Ssl 0:00 /usr/sbin/rsyslogd
1956 ? Ss 0:02 /usr/sbin/acpid
2076 ? Ss 0:03 /usr/sbin/irqbalance --pid=/var/run/irqbalance.pid
2116 ? Ss 0:01 /usr/sbin/gpm -m /dev/input/mice -t exps2
2162 ? Ss 0:00 /usr/sbin/cron
2180 ? Ss 0:00 /usr/sbin/cupsd -C /etc/cups/cupsd.conf -s /etc/cups/cups-files.conf
2197 ? Ss 0:51 /usr/bin/dbus-daemon --system
2222 ? S< 0:00 [iprt]
2273 ? S 0:00 /usr/sbin/bluetoothd
2339 ? S 0:00 avahi-daemon: running [antixroam.local]
2340 ? S 0:00 avahi-daemon: chroot helper
2412 ? S 1:48 /usr/bin/python -O /usr/share/wicd/daemon/wicd-daemon.py
2471 ? S 0:55 /usr/bin/python -O /usr/share/wicd/daemon/monitor.py
2473 ? S 0:00 [kworker/0:0]
2525 tty1 Ss+ 0:00 /sbin/getty --noclear 38400 tty1
2526 tty2 Ss+ 0:00 /sbin/getty 38400 tty2
2528 tty4 Ss+ 0:00 /sbin/getty 38400 tty4
2529 tty5 Ss+ 0:00 /sbin/getty 38400 tty5
2530 tty6 Ss+ 0:00 /sbin/getty 38400 tty6
2675 ? S 0:00 [kauditd]
2713 ? S< 0:00 [kdmflush]
2715 ? S< 0:00 [bioset]
2716 ? S< 0:00 [kcryptd_io]
2717 ? S< 0:00 [kcryptd]
2718 ? S< 0:00 [bioset]
2730 ? D 0:01 [jbd2/dm-0-8]
2731 ? S< 0:00 [ext4-rsv-conver]
2780 ? Ss 0:00 dhclient -v -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases eth0
2892 ? Sl 0:00 /usr/sbin/console-kit-daemon --no-daemon
2959 ? Sl 0:00 /usr/lib/policykit-1/polkitd --no-debug
4828 ? S 0:00 [kworker/0:2]
5395 ? Sl 1:18 /opt/google/chrome/chrome --type=renderer --enable-deferred-image-decoding --lang=en-US --force-fieldtrials=*AffiliationBasedMatching/Enabled/*CTRequiredForEVTrial/RequirementEnforced/CaptivePortalInterstitial/Disabled/*ChildAccountDetection/Disabled/ChromeDashboard/Default/*ChromeSuggestions/Default/*DomRel-Enable/enable/EnableSessionCrashedBubbleUI/Disabled/*EnhancedBookmarks/Extension (public)/*ExtensionContentVerification/Enforce/*ExtensionInstallVerification/None/*IconNTP/Default/*NewProfileManagement/Enabled/*OmniboxBundledExperimentV1/Stable_DisplayHintTextPrePeriod2/*PasswordGeneration/Disabled/PasswordLinkInSettings/Disabled/PermissionBubbleRollout/Enabled/*PrerenderFromOmnibox/OmniboxPrerenderEnabled/*QUIC/EnabledNoIdForLargePopulation/*RefreshTokenDeviceId/Enabled/*RememberCertificateErrorDecisions/OneWeek/SHA1IdentityUIWarning/Enabled/SHA1ToolbarUIJanuary2016/Warning/SHA1ToolbarUIJanuary2017/Error/*SafeBrowsingIncidentReportingService/Default/SessionRestoreBackgroundLoading/Restore/*SettingsEnforcement/no_enforcement/*SyncBackingDatabase32K/Disabled/*UMA-Dynamic-Binary-Uniformity-Trial/default/*UMA-Population-Restrict/normal/*UMA-Uniformity-Trial-1-Percent/group_29/*UMA-Uniformity-Trial-10-Percent/group_07/*UMA-Uniformity-Trial-10
5470 ? S 0:00 [kworker/u16:3]
5513 ? S 0:00 [kworker/7:0]
6219 ? S 0:00 [kworker/4:2]
6603 ? S 0:00 /usr/bin/jwm
6613 ? S 0:00 spacefm --desktop
6692 ? S 0:00 volumeicon
6693 ? S 0:00 fbxkb
6708 ? Sl 0:00 conky
6821 ? S 0:00 [kworker/0:1]
7267 ? S 0:01 [kworker/4:1]
7528 ? S 0:00 [kworker/u16:0]
7546 pts/1 Ss 0:00 /bin/bash
7599 ? S 0:00 [kworker/u16:2]
7849 pts/1 R+ 0:00 ps ax
13806 tty3 Ss+ 0:00 /sbin/getty 38400 tty3
15616 ? S 0:01 [kworker/3:2]
19863 ? S 0:00 [kworker/5:0]
20820 ? S 0:01 [kworker/2:0]
21277 ? S 0:02 [kworker/3:0]
22804 ? S 0:02 [kworker/2:1]
23130 ? S 0:03 [kworker/6:0]
23161 ? S 0:00 [kworker/5:2]
25377 ? Ssl 0:28 mocp
26788 ? S 0:01 [kworker/1:1]
26879 ? S 0:00 [irq/43-mei_me]
27064 ? S 0:01 [kworker/7:2]
27356 ? S 0:00 [kworker/6:1]
27679 ? Ss 0:00 /usr/bin/slim -d
27682 tty7 Ss+ 0:47 /usr/bin/X11/X -dpi 96 -nolisten tcp -auth /var/run/slim.auth vt07
27703 ? Ss 0:00 /bin/bash /usr/local/bin/desktop-session rox-fluxbox
27929 ? S 0:00 /usr/bin/dbus-launch --autolaunch 20d620618be3dac6cccc0a2755669a0d --binary-syntax --close-stderr
27930 ? Ss 0:00 /usr/bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
27932 ? S 0:00 /usr/lib/i386-linux-gnu/gconf/gconfd-2
28399 ? Ss 0:00 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -C /run/wpa_supplicant
28494 ? Ss 0:00 dhclient -v -pf /run/dhclient.wlan0.pid -lf /var/lib/dhcp/dhclient.wlan0.leases wlan0
28572 ? Ss 0:00 /usr/sbin/sshd
29865 ? S 0:00 /bin/bash /usr/local/bin/desktop-defaults-run -b
29866 ? Sl 1:08 /opt/google/chrome/chrome
29873 ? S 0:00 cat
29874 ? S 0:00 cat
29876 ? S 0:00 /opt/google/chrome/chrome-sandbox /opt/google/chrome/chrome --type=zygote
29877 ? S 0:00 /opt/google/chrome/chrome --type=zygote
29879 ? S 0:00 /opt/google/chrome/chrome-sandbox /opt/google/chrome/nacl_helper
29880 ? S 0:00 /opt/google/chrome/nacl_helper
29882 ? S 0:00 /opt/google/chrome/chrome --type=zygote
29899 ? Sl 0:40 /opt/google/chrome/chrome --type=gpu-process --channel=29866.0.1776143543 --supports-dual-gpus=false --gpu-driver-bug-workarounds=2,7,14,43 --disable-accelerated-video-decode --gpu-vendor-id=0x8086 --gpu-device-id=0x0166 --gpu-driver-vendor --gpu-driver-version
29907 ? S 0:00 /opt/google/chrome/chrome --type=gpu-broker
29934 ? Sl 0:03 /opt/google/chrome/chrome --type=renderer --enable-deferred-image-decoding --lang=en-US --force-fieldtrials=AffiliationBasedMatching/Enabled/*CTRequiredForEVTrial/RequirementEnforced/CaptivePortalInterstitial/Disabled/*ChildAccountDetection/Disabled/ChromeDashboard/Default/*ChromeSuggestions/Default/*DomRel-Enable/enable/EnableSessionCrashedBubbleUI/Disabled/*EnhancedBookmarks/Extension (public)/*ExtensionContentVerification/Enforce/*ExtensionInstallVerification/None/*IconNTP/Default/*NewProfileManagement/Enabled/*OmniboxBundledExperimentV1/Stable_DisplayHintTextPrePeriod2/*PasswordGeneration/Disabled/PasswordLinkInSettings/Disabled/PermissionBubbleRollout/Enabled/PrerenderFromOmnibox/OmniboxPrerenderEnabled/*QUIC/EnabledNoIdForLargePopulation/*RefreshTokenDeviceId/Enabled/*RememberCertificateErrorDecisions/OneWeek/SHA1IdentityUIWarning/Enabled/SHA1ToolbarUIJanuary2016/Warning/SHA1ToolbarUIJanuary2017/Error/*SafeBrowsingIncidentReportingService/Default/SessionRestoreBackgroundLoading/Restore/*SettingsEnforcement/no_enforcement/SyncBackingDatabase32K/Disabled/*UMA-Dynamic-Binary-Uniformity-Trial/default/*UMA-Population-Restrict/normal/*UMA-Uniformity-Trial-1-Percent/group_29/*UMA-Uniformity-Trial-10-Percent/group_07/*UMA-Uniformity-Trial-100-P
29943 ? Sl 0:00 /opt/google/chrome/chrome --type=renderer --enable-deferred-image-decoding --lang=en-US --force-fieldtrials=AffiliationBasedMatching/Enabled/*CTRequiredForEVTrial/RequirementEnforced/CaptivePortalInterstitial/Disabled/*ChildAccountDetection/Disabled/ChromeDashboard/Default/*ChromeSuggestions/Default/*DomRel-Enable/enable/EnableSessionCrashedBubbleUI/Disabled/*EnhancedBookmarks/Extension (public)/*ExtensionContentVerification/Enforce/*ExtensionInstallVerification/None/*IconNTP/Default/*NewProfileManagement/Enabled/*OmniboxBundledExperimentV1/Stable_DisplayHintTextPrePeriod2/*PasswordGeneration/Disabled/PasswordLinkInSettings/Disabled/PermissionBubbleRollout/Enabled/PrerenderFromOmnibox/OmniboxPrerenderEnabled/*QUIC/EnabledNoIdForLargePopulation/*RefreshTokenDeviceId/Enabled/*RememberCertificateErrorDecisions/OneWeek/SHA1IdentityUIWarning/Enabled/SHA1ToolbarUIJanuary2016/Warning/SHA1ToolbarUIJanuary2017/Error/*SafeBrowsingIncidentReportingService/Default/SessionRestoreBackgroundLoading/Restore/*SettingsEnforcement/no_enforcement/SyncBackingDatabase32K/Disabled/*UMA-Dynamic-Binary-Uniformity-Trial/default/*UMA-Population-Restrict/normal/*UMA-Uniformity-Trial-1-Percent/group_29/*UMA-Uniformity-Trial-10-Percent/group_07/*UMA-Uniformity-Trial-100-P
29950 ? Sl 0:04 /opt/google/chrome/chrome --type=renderer --enable-deferred-image-decoding --lang=en-US --force-fieldtrials=AffiliationBasedMatching/Enabled/*CTRequiredForEVTrial/RequirementEnforced/CaptivePortalInterstitial/Disabled/*ChildAccountDetection/Disabled/ChromeDashboard/Default/*ChromeSuggestions/Default/*DomRel-Enable/enable/EnableSessionCrashedBubbleUI/Disabled/*EnhancedBookmarks/Extension (public)/*ExtensionContentVerification/Enforce/*ExtensionInstallVerification/None/*IconNTP/Default/*NewProfileManagement/Enabled/*OmniboxBundledExperimentV1/Stable_DisplayHintTextPrePeriod2/*PasswordGeneration/Disabled/PasswordLinkInSettings/Disabled/PermissionBubbleRollout/Enabled/PrerenderFromOmnibox/OmniboxPrerenderEnabled/*QUIC/EnabledNoIdForLargePopulation/*RefreshTokenDeviceId/Enabled/*RememberCertificateErrorDecisions/OneWeek/SHA1IdentityUIWarning/Enabled/SHA1ToolbarUIJanuary2016/Warning/SHA1ToolbarUIJanuary2017/Error/*SafeBrowsingIncidentReportingService/Default/SessionRestoreBackgroundLoading/Restore/*SettingsEnforcement/no_enforcement/SyncBackingDatabase32K/Disabled/*UMA-Dynamic-Binary-Uniformity-Trial/default/*UMA-Population-Restrict/normal/*UMA-Uniformity-Trial-1-Percent/group_29/*UMA-Uniformity-Trial-10-Percent/group_07/*UMA-Uniformity-Trial-100-P
30061 ? Sl 0:39 /opt/google/chrome/chrome --type=renderer --enable-deferred-image-decoding --lang=en-US --force-fieldtrials=*AffiliationBasedMatching/Enabled/*CTRequiredForEVTrial/RequirementEnforced/CaptivePortalInterstitial/Disabled/*ChildAccountDetection/Disabled/ChromeDashboard/Default/*ChromeSuggestions/Default/*DomRel-Enable/enable/EnableSessionCrashedBubbleUI/Disabled/*EnhancedBookmarks/Extension (public)/*ExtensionContentVerification/Enforce/*ExtensionInstallVerification/None/*IconNTP/Default/*NewProfileManagement/Enabled/*OmniboxBundledExperimentV1/Stable_DisplayHintTextPrePeriod2/*PasswordGeneration/Disabled/PasswordLinkInSettings/Disabled/PermissionBubbleRollout/Enabled/PrerenderFromOmnibox/OmniboxPrerenderEnabled/*QUIC/EnabledNoIdForLargePopulation/*RefreshTokenDeviceId/Enabled/*RememberCertificateErrorDecisions/OneWeek/SHA1IdentityUIWarning/Enabled/SHA1ToolbarUIJanuary2016/Warning/SHA1ToolbarUIJanuary2017/Error/*SafeBrowsingIncidentReportingService/Default/SessionRestoreBackgroundLoading/Restore/*SettingsEnforcement/no_enforcement/*SyncBackingDatabase32K/Disabled/*UMA-Dynamic-Binary-Uniformity-Trial/default/*UMA-Population-Restrict/normal/*UMA-Uniformity-Trial-1-Percent/group_29/*UMA-Uniformity-Trial-10-Percent/group_07/*UMA-Uniformity-Trial-100
30156 ? Sl 1:57 /opt/google/chrome/chrome --type=renderer --enable-deferred-image-decoding --lang=en-US --force-fieldtrials=*AffiliationBasedMatching/Enabled/*CTRequiredForEVTrial/RequirementEnforced/CaptivePortalInterstitial/Disabled/*ChildAccountDetection/Disabled/ChromeDashboard/Default/*ChromeSuggestions/Default/*DomRel-Enable/enable/EnableSessionCrashedBubbleUI/Disabled/*EnhancedBookmarks/Extension (public)/*ExtensionContentVerification/Enforce/*ExtensionInstallVerification/None/*IconNTP/Default/*NewProfileManagement/Enabled/*OmniboxBundledExperimentV1/Stable_DisplayHintTextPrePeriod2/*PasswordGeneration/Disabled/PasswordLinkInSettings/Disabled/PermissionBubbleRollout/Enabled/PrerenderFromOmnibox/OmniboxPrerenderEnabled/*QUIC/EnabledNoIdForLargePopulation/*RefreshTokenDeviceId/Enabled/*RememberCertificateErrorDecisions/OneWeek/SHA1IdentityUIWarning/Enabled/SHA1ToolbarUIJanuary2016/Warning/SHA1ToolbarUIJanuary2017/Error/*SafeBrowsingIncidentReportingService/Default/SessionRestoreBackgroundLoading/Restore/*SettingsEnforcement/no_enforcement/*SyncBackingDatabase32K/Disabled/*UMA-Dynamic-Binary-Uniformity-Trial/default/*UMA-Population-Restrict/normal/*UMA-Uniformity-Trial-1-Percent/group_29/*UMA-Uniformity-Trial-10-Percent/group_07/*UMA-Uniformity-Trial-100
30882 ? S 0:00 /bin/bash /usr/local/bin/desktop-defaults-run -t
30883 ? Sl 0:02 roxterm
30885 ? S 0:00 gnome-pty-helper
30886 pts/0 Ss+ 0:00 /bin/bash
Charlie
8 ? S 0:00 [rcu_bh]
51 ? SN 0:00 [ksmd]
6693 ? S 0:00 fbxkb
29873 ? S 0:00 cat
29874 ? S 0:00 cat
The session manager and therefor the startup in the session manager should be doing this.... if it is started in there it should restart on a session reload. Now my question to this... is the syndaemon in the session startup? Without it being in the session scripting you will run into troubles like this being that the program loads for one session and then has to try and apply what it has loaded to a new session. We are attempting to make a "community startup area" as you call it in the session manager (desktop-session). So before trouble shooting any further it does need to be in /etc/desktop-session/startup NOT ~/.icewm/startup to have the best chance of working for all window managers.kd5ob wrote: As you will see 29018 ? Ss 0:00 syndaemon -d -t -=-------- it's still running just fine.
Please note it could very well be a bug that you have found in the new session manager. If this is the case and you can flip to, and run in the console, could you copy the ~/.desktop-session/log file when on rox-jwm then switch back to another desktop and paste here? This will only apply if you still have the issue and it is in /etc/desktop-session/startup NOT ~/.icewm/startup
Okay, removing syndaemon -d -t & from .icewm/startup and putting it in the /etc/desktop-session/startup file instead and rebooting.
Loggin into space-ice
I do a ps ax for my syndaemon before anything else.
kd5ob@antixroam:~
$ ps ax |grep sy
1908 ? Ssl 0:00 /usr/sbin/rsyslogd
2194 ? Ss 0:00 /usr/bin/dbus-daemon --system
2958 ? Ss 0:00 syndaemon -d -t
3008 ? S 0:00 /usr/bin/dbus-launch --autolaunch 20d620618be3dac6cccc0a2755669a0d --binary-syntax --close-stderr
3051 pts/0 S+ 0:00 grep sy
Choosing alternate desktop rox-jwm now and I do another PS AX command and we get.
kd5ob@antixroam:~
$ ps ax |grep sy
3831 ? Ss 0:00 syndaemon -d -t
3912 pts/0 S+ 0:00 grep sy
There are 2 running now.
So , I post the log file requested in your message here.
kd5ob@antixroam:~
kd5ob@antixroam:~/.desktop-session
$ cat log
desktop-session: started Sat May 30 20:31:38 CDT 2015 start_time: 47.68
desktop-session: pid: 2820
desktop-session: logging to: /home/kd5obantix/.desktop-session/log
desktop-session: launch @ 4785
desktop-session: look up executable for icewm
desktop-session: save desktop code: space-icewm
desktop-session: Exporting desktop Variables:
desktop-session: DESKTOP_SESSION_CODE=space-icewm
desktop-session: DESKTOP_SESSION_WM=icewm
desktop-session: DESKTOP_SESSION_IM=space
desktop-session: run: /usr/bin/icewm-session
icewm-session: Warning: File still open: fd=3, target='/var/log/slim.log' (missing FD_CLOEXEC?)
icewm-session: Warning: Closing file descriptor: 3
icewm-session: icewm-session: using /home/kd5obantix/.icewm for private configuration filesWarning:
icewmbg: using /home/kd5obantix/.icewm for private configuration files
IceWM: using /home/kd5obantix/.icewm for private configuration files
icewmtray: using /home/kd5obantix/.icewm for private configuration files
desktop-session: Checking for running window manager @ 4950
desktop-session: Window manager running or setup forced, setting up desktop @ 5003
desktop-session: Delaying session startup by 2 seconds
desktop-session: run: spacefm --desktop &
** (spacefm:2874): WARNING **: No root settings found in /etc/spacefm/ Setting a root editor in Preferences should remove this warning on startup. Otherwise commands run as root may present a security risk.
desktop-session: run: desktop-session-wallpaper
desktop-session: run: desktop-menu --write-out-global
desktop-session: Destination file is newer than the Source file.
desktop-session: run: /etc/desktop-session/startup &
desktop-session: run: sleep 2
Conky: forked to background, pid is 2966
desktop-session: run: xset dpms 10800 10800 10800 s 10800 10800
Conky: desktop window (800003) is subwindow of root window (a0)
Conky: window type - normal
Conky: drawing to created window (0x1800001)
Conky: drawing to double buffer
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
** (roxterm:3004): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
** (roxterm:3004): WARNING **: Failed to connect to session manager: SESSION_MANAGER environment variable not defined
[3088:3088:0530/203208:ERROR:url_pattern_set.cc(240)] Invalid url pattern: chrome://print/*
[3216:3216:0531/013215:ERROR:gles2_cmd_decoder.cc(11539)] [GroupMarkerNotSet(crbug.com/242999)!:68C010BA]GL ERROR :GL_INVALID_OPERATION : glTexStorage2DEXT: <- error from previous GL command
[3088:3088:0530/203215:ERROR:CONSOLE(70)] "Uncaught Error: Attempting to use a disconnected port object", source: extensions::messaging (70)
[3088:3364:0530/203220:ERROR:get_updates_processor.cc(243)] PostClientToServerMessage() failed during GetUpdates
[3088:3088:0530/203221:ERROR:extension_downloader.cc(695)] Invalid URL: '' for extension dplneigckkjefigcmhdjfbdkdfgammge
[3216:3216:0531/013222:ERROR:gles2_cmd_decoder.cc(11539)] [GroupMarkerNotSet(crbug.com/242999)!:68E441BE]GL ERROR :GL_INVALID_OPERATION : glTexStorage2DEXT: <- error from previous GL command
desktop-session-restart: Started
desktop-session-restart: old code: space-icewm
desktop-session-restart: new code: rox-jwm
desktop-session-logout: Started
desktop-session-logout: run: exec setsid /usr/local/lib/desktop-session/desktop-session-logout extra args
desktop-session-logout: found ppid file. ppid: 2820
desktop-session-logout: Kill desktop-session group: 2820
desktop-session-logout: run: kill_list 2853 2874 2955 2956 2966
desktop-session-logout: ps_debug(2853 2874 2955 2956 2966)
desktop-session-logout: PPID PID PGID SID TTY TPGID STAT UID TIME COMMAND
desktop-session-logout: 2820 2853 2820 2820 ? -1 S 1000 0:00 /usr/bin/icewm-session
desktop-session-logout: 1 2874 2820 2820 ? -1 S 1000 0:00 spacefm --desktop
desktop-session-logout: 1 2955 2820 2820 ? -1 S 1000 0:00 volumeicon
desktop-session-logout: 1 2956 2820 2820 ? -1 S 1000 0:00 fbxkb
desktop-session-logout: 1 2966 2820 2820 ? -1 Sl 1000 0:00 conky
Conky: received SIGINT or SIGTERM to terminate. bye!
desktop-session-logout: Waiting for termination of: 2853 2874 2955 2956 2966
desktop-session: restart rox-jwm
desktop-session: launch rox-jwm @ 18617
desktop-session: look up executable for jwm
desktop-session: save desktop code: rox-jwm
desktop-session: DESKTOP_SESSION_CODE=rox-jwm
desktop-session: DESKTOP_SESSION_WM=jwm
desktop-session: DESKTOP_SESSION_IM=rox
desktop-session: run: /usr/bin/jwm
desktop-session: Checking for running window manager @ 18620
desktop-session-logout: All processes died within .1 seconds
JWM: warning: /home/kd5obantix/.jwmrc[6]: could not open included file /home/kd5obantix/.jwm/startup
JWM: warning: bad color: ""
desktop-session: Window manager running or setup forced, setting up desktop @ 18671
desktop-session: run: rox --pinboard=antiX-jwm &
Conky: forked to background, pid is 3842
Conky: desktop window (a000a0) is subwindow of root window (a0)
I'VE NOTICED I CAN'T TOUCHPAD SCROLL ANYTHING AT THIS POINT. RIGHT TOUCH PAD
CLICK NO LONGER BRINGS UP MENU. CONKY IS BLURPING OUT ON THE DISPLAY BAR GRAPHS.
NEXT, I SWITCH BACK TO SPACE-ICE AND DO THE SAME..
PS AX FIRST.
$ ps ax |grep sy
4607 ? Ss 0:00 syndaemon -d -t
4810 pts/0 S+ 0:00 grep sy
I see I have 3 syndaemons now.
Next, we print the log out again....
$ cat log
desktop-session-restart: old code: rox-jwm
desktop-session-restart: new code: space-icewm
desktop-session-logout: run: kill_list 3748 3766 3828 3829 3842
desktop-session-logout: ps_debug(3748 3766 3828 3829 3842)
desktop-session-logout: 2820 3748 2820 2820 ? -1 S 1000 0:00 /usr/bin/jwm
desktop-session-logout: 1 3766 2820 2820 ? -1 S 1000 0:00 rox --pinboard=antiX-jwm
desktop-session-logout: 1 3828 2820 2820 ? -1 S 1000 0:00 volumeicon
desktop-session-logout: 1 3829 2820 2820 ? -1 S 1000 0:00 fbxkb
desktop-session-logout: 1 3842 2820 2820 ? -1 Sl 1000 0:00 conky
desktop-session-logout: Waiting for termination of: 3748 3766 3828 3829 3842
desktop-session: restart space-icewm
desktop-session: launch space-icewm @ 37731
desktop-session: Checking for running window manager @ 37732
desktop-session: Window manager running or setup forced, setting up desktop @ 37784
** (spacefm:4535): WARNING **: No root settings found in /etc/spacefm/ Setting a root editor in Preferences should remove this warning on startup. Otherwise commands run as root may present a security risk.
Conky: forked to background, pid is 4615
Conky: desktop window (1000003) is subwindow of root window (a0)
Conky: drawing to created window (0x3200001)
$ ps ax |grep sy
And that's that....
Hope this helps some.
Charlie
kd5ob@antixroam:~
$ ps ax |grep sy
kd5ob@antixroam:~
$ ps ax |grep sy
kd5ob@antixroam:~
$ cat log
PS AX FIRST.
$ ps ax |grep sy
$ cat log
$ ps ax |grep sy
And that's that....
Charlie
NOW,,, after having done all that,,,
I log OUT and log back in on space-ice and
everything works perfectly with only one
instance of syndaemon in memory.
So, when we switch WM's, it's not stopping
and restaring this.
Scroll's back,,, everything is back again with one logout and log back in again.
Charlie
and restaring this.
Charlie
