Kudos MX18 Jan. 2019 snapshot
Latest sprint with MX18 has been the most positive yet!
Pros:
-sleep mode issue (not waking up from) has been resolved;
-boot/shutdown speed = Solus Budgie (best IMO);
-wallpapers choice just fine;
-the installation process is a breeze.
Cons:
-just a bit of screen tearing.
-did take 3 reboots before HP printer was able to work.
Pros:
Cons:
- Eadwine Rose
- Administrator
Re: Kudos MX18 Jan. 2019 snapshot
Screen tearing really depends on the hardware of the user and is also happening on a regular MX18 install. But that can easily be fixed after the install.
Compositor off doesn't make a difference.
KDE distros don't usually have this issue.
If you have other tips, i'm game!
What graphic card do you have? Have you installed the Nvidia driver (in case you use Nvidia)? Maybe you are using the wrong driver.
Device-1: AMD Seymour [Radeon HD 6400M/7400M Series]
vendor: Hewlett-Packard driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.19.2 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1600x900~60Hz, 1680x1050~60Hz
OpenGL: renderer: AMD CAICOS (DRM 2.50.0 / 4.19.0-1-amd64 LLVM 7.0.0)
v: 3.3 Mesa 18.2.6 direct render: Yes
have you tried using the compton compositor? its in MX-tweaks -> compositor tab
Thanks, but Compton makes no change happen either.
At first i thought it might be a Firefox thing, but it happens in Vivaldi as well.
The "horizontal line" appears more precise in the latter.
I can create that .txt file with LibreOffice but can't save or paste it into that folder.
See how non-geek i am!
Create it in FeatherPad, and see if that helps.
