MX User Manager
deepestfishguy
MX User Manager
#1 Post by deepestfishguy »
2019-05-16
I would like to set up a Guest account that would not require a password. Is it possible to do this? Are there risks involved in doing this, even if the Guest account is set up without any privileges?
JayM
Qualified MX Guide
Re: MX User Manager
#2 Post by JayM »
deepestfishguy wrote: Thu May 16, 2019 7:49 pm 2019-05-16
No. Passwords are required for user authentication.
Yes, extreme risks. Letting an unverified, unvalidated account run at any privilege level would be a very bad thing, security-wise. That's why passwords are a system requirement and always have been in Linux, and in Unix before that.
Welcome to the forum.
deepestfishguy
Re: MX User Manager
#3 Post by deepestfishguy »
Thanks so much for your speedy reply !!
manyroads
Re: MX User Manager
#4 Post by manyroads »
Truly a bad idea... sorry. :welcome:
deepestfishguy
Re: MX User Manager
#5 Post by deepestfishguy »
I value your input . . . thanks for a quick reply . . . no need for me to think about this anymore !!
deepestfishguy
RSOLVED: MX User Manager
#6 Post by deepestfishguy »
Not sure if it is protocol on this Form to indicate that an issue has been resolved . . . hopefully it is appropriate for me to do so. Cheers !!
Re: RSOLVED: MX User Manager
#7 Post by richb »
deepestfishguy wrote: Thu May 16, 2019 8:33 pm Not sure if it is protocol on this Form to indicate that an issue has been resolved . . . hopefully it is appropriate for me to do so. Cheers !!
It is. Add [Solved] to the title of your first post. The pencil at the right top of the post block will put you in editing mode.
Vincent17
Re: MX User Manager
#8 Post by Vincent17 »
JayM wrote:Yes, extreme risks. Letting an unverified, unvalidated account run at any privilege level would be a very bad thing, security-wise.
For my education, could you elaborate?
Do you assume computer is accessible to strangers physically or via network?
Is autologin even worse?
Thanks for your patience.
manyroads
Re: MX User Manager
#9 Post by manyroads »
Vincent17 wrote: Sat May 18, 2019 11:53 am
If your PC is plugged into any network... and you have an open account, anyone with access to that network has free and open access to your machine.
j2mcgreg
Re: MX User Manager
#10 Post by j2mcgreg »
You only have to look at the Windows platform to find your answer. Microsoft wanted Windows (especially the Home versions) to be as user friendly as possible. To that end they eschewed passwords early on in the consumer versions and also made passwords trivial to bypass on the business versions. They also gave their office suite kernel access. Then they rolled out a security protocol which was so strict that every home user had to be an Administrator. The effect of these four policies was to create an environment that enabled a plague of viruses and malware to occur.
